  2. Announcements
  3. MCAL Release Notes
  4. YTM32B1ME0_2_3_0 Release Notes
已定时 已固定 已锁定 已移动 MCAL Release Notes
1 帖子 1 发布者 2.5k 浏览
    Overview
    YUNTU MCAL(Microcontroller Abstract Layer) software package is designed by YTMicro AE team to support customers on AUTOSAR compliant application software development. The YUNTU MCAL is developed according to the AUTOSAR CP Release v4.4.0 standard.
    Package Name Version Release Date
    YTM32B1ME0_2_3_0 2_3_0 2025-07-22
    Support Toolchains
    YUNTU MCAL software package release are tested and validated with the following toolchains/IDE:
    Recommended Configuration Tool:
    • YCT(Yuntu Config Tool) v2.7.4 or higher version
    Tips: It can be downloaded from YTMicro Account or updated from the installed older version YCT.
    Recommended IDE/Compilers:
    • ARM Keil v5.36 or higher version IDE
    • IAR v8.40 or higher version IDE
    • VSCode v1.80 or higher version IDE with Ninja, CMake and GCC/IAR/Keil as compiler
    • GCC for ARM v10.3 or higher version
    Recommended debuger:
    • SEGGER J-INK v9.2 or higher hardware + v6.96 or higher software/driver with required YTM32B1ME05 and YTM32B1MD14 patch installed.
    Release List
    • [Fix]-[CddUart]-[2] Fix the issue where the global variable was unexpectedly modified due to reentrancy of the transmission interface in CddUart when using the OS
    • [Fix]-[CddUart]-[1] Fix an incorrect variable MemMap definition issue
    • [Opt]-[CddUart]-[0] Renaming the function names in the Lld layer
    • [Fix]-[CddUart]-[2] Fix CddUart has a probability of entering hardfault after DeInit issue.
    • [Opt]-[CddUart]-[1] Add a clock check to XDM for the CddUart function clock and adjust the upper limit condition for the baud rate
    • [Opt]-[CddUart]-[0] Update CddUart channel Symbolic Name
    • [Fix]-[Icu]-[2] Fix the problem that IcuCmp can't enter interrupt.
    • [Fix]-[Icu]-[2] Fix the issue of incorrect assignment of the array variable IcuWkupPortBuff in the ICU code.
    • [Fix]-[Icu]-[1] Optimize the working mode and clock configuration issues of Icu ACMP.
    • [Fix]-[Icu]-[0] Fix the error that occurs when configuring the number of Etmr channels in YCT
    • [Fix]-[Crypto]-[2] Fixed the issue of abnormal SHA signature calculation results in the Crypto module.
    • [Fix]-[Crypto]-[2] Fixed the bug that the Crypto Job only allowed a single Update operation.
    • [Opt]-[Gpt]-[1] Fix the bug Gpt Irq handler does not check whether the interrupt is enabled
    • [Fix]-[Gpt]-[1] Fix the bug that when the lptmr select 'LPTMR0_CLK' the verification fail
    • [Opt]-[Gpt]-[1] Fix the bug GptWakeupConfiguration option could not be edited
    • [New]-[Gpt]-[1] Add a way to update the CMP value of the TMR in continuous mode
    • [Opt]-[Gpt]-[0] remove the out-of-date comment in xdm
    • [Fix]-[Adc]-[0] Add unit test case for Adc_Irq.c
    • [Opt]-[Adc]-[0] Update the qac test for Fls and Adc modules
    • [Fix]-[Adc]-[2] Fix Adc hardware index data overflow bug
    • [Fix]-[Adc]-[2] Fix compilation error when the group queue is disabled
    • [New]-[Adc]-[2] Add adc power mode configuration and APIs support
    • [Fix]-[Adc]-[2] Fixed a bug when ADC was configured to hardware trigger with DMA
    • [Fix]-[Adc]-[2] Fix the issue of abnormal data when the ADC module uses DMA to transfer results.
    • [Fix]-[Adc]-[2] Fix errata E60005
    • [Fix]-[Platform]-[1] SchM code size optimization
    • [Fix]-[Platform]-[2] empty ivt when define USING_OS_AUTOSAROS
    • [Opt]-[Pwm]-[1] Fix issue of Pwm period and dutycycle error due to eTMR errata 3 inappropriate application
    • [Fix]-[Pwm]-[2] Pwm eTmer deatime insert bug fix
    • [Fix]-[Can]-[0] Fix the bug when hardware MB is more than 0xFF
    • [Fix]-[Can]-[1] Fix Can two frame with same MB hit bug
    • [Fix]-[Can]-[1] Can ssp need add 1
    • [Fix]-[Fee]-[0] Delete unused valid rule in Fee/FeeClusterGroup/FeeCluster/FeeSector/FeeSectorRef
    • [Fix]-[Fee]-[2] Fixing the bug of potential write failures after a "Cancel" operation
    • [Fix]-[Fee]-[3] Fix Fee cause busfault when called Fee Api with a invalid block number
    • [New]-[Fee]-[2] Added the cluster group running data reading API in Fee
    • [Opt]-[Fee]-[2] Fixing the bug of potential write failures after a "Cancel" operation.
    • [Fix]-[CddDma]-[2] Fix certain API conflicts between the CddDma and DmaTst modules
    • [Opt]-[CddDma]-[0] Fix ISR wrapper of Spi CddI2c CddUart and CddDma
    • [Fix]-[Fls]-[2] Fls_Erase sector length limit bug fix
    • [New]-[Fls]-[3] Add the code of the mld layer in the Fls module
    • [Fix]-[Fls]-[3] Upgrade the Fls operation procedure
    • [Opt]-[CddI2c]-[1] Change the I2C transmission data length type from uint8 to uint16, and modifiy the DeInit IP with IPC soft reset
    • [Fix]-[CddI2c]-[1] Fix the issue of Det_ReportRuntimeError function dependency on DET enablement, Det_ReportRuntimeError report should be always on
    • [Opt]-[Spi]-[0] Enabled SPI Error interrupt when using DMA
    • [Fix]-[Spi]-[2] Fix core bus fault caused by SPI accidentally entering interrupt
    • [Fix]-[Spi]-[2] If another task preempts and calls the asynchronous polling interface before the SPI synchronous transmission is completed, it will cause transmission anomalies, when using OS.
    • [Fix]-[Spi]-[2] Fix spi Pcs polarity configure bug
    • [Fix]-[Spi]-[1] Fix the SPI master's maximum frequency of operation limitation issue
    • [Opt]-[Lin]-[1] update LinNodeType range name in configuration according to AUTOSAR.
    • [Opt]-[Lin]-[1] Update Node Type name according to AutoSAR
    • [Fix]-[Lin]-[1] Update Lin_FrameResponseType according to 4.4.0 AUTOSAR specification of LIN Driver
    • [Opt]-[Lin]-[1] Fix the LIN_SLAVE_API_SUPPORT LIN_MASTER_API_SUPPORT precompiled macro switch location bug
    • [Fix]-[Wdg]-[2] Fixed the issue that the generated defaultMode is always WDGIF_SLOW_MODE
    • [Fix]-[Wdg]-[1] Fix the include bug that compilation error when only WDG0 module is added without WDG1 module
    • [Opt]-[Mcu]-[3] Fix the issue pll predivider maybe 2
    • [Fix]-[Mcu]-[0] Mcu ipc clock frequency update for spi
    • [Fix]-[Mcu]-[4] Software should sweep FXOSC gain setting when enable FXOSC
    • [Fix]-[Port]-[0] Port compile warning for GHS
    • [Fix]-[Ocu]-[2] Fix the issue where Ocu reports a MemManage fault in user mode
    • [Opt]-[Mcal]-[0] Opt Examples
    Annex
    Release list naming rule
    Each release list item shall contain the following elements:
    [Type] - [Sub-Type/Module] - [Effect_Level] [Brief/Overview Description][Reference/Details Link]
    • [Type]
      • Fix: Bug fixes / issue resolution
      • Opt: Code performance optimization
      • New: New feature implementation
      • Demo: Example / demonstration project
      • Doc: Documentation updates
    • [Sub-Type/Module]
      • MCAL: Mcu/Dio/Port/Can/Lin/Spi/Gpt/Pwm/Adc/Icu/Ocu/Fls/Fee/Platform/CddUart/CddSai/CddPpu/CddI2c/CddDma/CddTrg
      • SafLib: CorTst/RamTst/FlsTst/IntTst/WdgTst/CrcTst/DmaTst/PpuTst/EfmTst/StkTst/EccTst/FmuTst
      • GUI: the YCT XDM config GUI update for the MCAL/SafLib SW package, the YCT Vue config GUI update for the SDK/Middleware SW package(no code change/modification)
    • [Effect_Level]
      • 0: No effect to the old version SW/project
      • 1: Recommend but optional to update, for example the performance optimization
      • 2: Must update for a specified SW module/components if the customer application used the related feature/functionality
      • 3: Must update for a specified SW module/components if it is used
      • 4: Must update if the SDK/MCAL/SafLib package is used
    • [Brief/Overview Description]
      • [Type] = Fix: Fixed the xxx issue/bug of the yyy HW/SW functionality/feature caused by condition
      • [Type] = Opt: Optimized the performance of the yyy HW/SW functionality/feature
      • [Type] = New: Added the new feature/functionality support of xxx
      • [Type] = Demo: added/updated the demo project: brief description
    • [Reference/Details Link]
      • Errata: give out the detailed Errata number
      • others: the link to the bug/issue analysis, it can be:
        • Link to a YUNTU form post [if it is derived from a FAE/customer feedback]
        • Link to a YUNTU form blog [if it is derived from a YUNTU form blog discussion]
    Disclaimer
    Copyright and Contact Information
    YTMicro and its subsidiaries reserve the right to change, correct, enhance, modify and improve YTMicro products or this document at any time without notice. Before placing an order, purchasers should obtain and understand the latest relevant information about the products. YUNTU's products are sold according to YUNTU team and sales conditions at the time of order confirmation. Purchasers have the sole responsibility for selecting, choosing and using YUNTU products, and YUNTU has no responsibility for assisting purchasers in product design and application. YUNTU does not grant any express or implied license to any intellectual property herein. Resale of YUNTU products with information different from that described herein will make any warranty of YUNTU for such product void. YTMicro and YTMicro logo are trademarks of YTMicro. All other product or service names are the property of their respective owners. The information in this document replaces and supersedes any previously provided information in any prior version of this document. © 2020 - 2023 YUNTU Microelectronics co.,ltd. All rights reserved.
    Contact us: Website: www.ytmicro.com.
    • FrankieF Frankie 从 中的 MCAL Private Issues 移动了该主题
    chenshaodongC
    chenshaodong
