  4. 一例将外部时钟引脚初始化为GPIO后,芯片无法连接。
2 帖子 2 发布者 817 浏览
  • jinyiJ 离线
    jinyiJ 离线
    jinyi
    问题描述
    • 某客户在BoardInit阶段将外部时钟引脚(如 OSC_IN/OSC_OUT)误配置为 GPIO,导致设备上电后 SWD 调试接口无法连接。
    客户诉求
    • 是否有可行的芯片恢复(解砖)方案?已尝试连接nRESET。
    • 云途是否可提供防呆机制,避免类似误配再次导致调试口失联?
    连接日志如下
    Connecting ...
     - Connecting via USB to probe/ programmer device 0
     - Probe/ Programmer firmware: J-Link V9 compiled Dec 13 2022 11:14:50
     - Probe/ Programmer S/N: 25952305
     - Device "YTM32B1ME05" selected.
     - Target interface speed: 4000 kHz (Fixed)
     - VTarget = 3.288V
     - Found SW-DP with ID 0x6BA02477
     - DPv0 detected
     - CoreSight SoC-400 or earlier
     - Scanning AP map to find all available APs
     - AP[0]: Stopped AP scan as end of AP map seems to be reached
     - Iterating through AP map to find AHB-AP to use
     - Attach to CPU failed. Executing connect under reset.
     - DPv0 detected
     - Could not find core in Coresight setup
     - Failed to power up DAP
      如果引脚初始化在时钟初始化之后,可以尝试短接晶振的两个引脚,让MCU停在时钟初始化,此时用JLINK尝试连接,Halt并擦除,或者保持这个状态下进行重新烧录,注意短接之后进行一次重新上下电操作。
      在异常状态直接短接或者复位应该无法直接恢复,必须要重新上下电。
      番茄+两个蛋番
      HAIYANGH
      HAIYANG
      hq123H
      hq123
      ganyongchaoG
      ganyongchao
