一例将外部时钟引脚初始化为GPIO后,芯片无法连接。
已锁定
已解决
YTM32B1M系列
问题描述
- 某客户在BoardInit阶段将外部时钟引脚(如 OSC_IN/OSC_OUT)误配置为 GPIO,导致设备上电后 SWD 调试接口无法连接。
客户诉求
是否有可行的芯片恢复(解砖)方案?已尝试连接nRESET。
云途是否可提供防呆机制,避免类似误配再次导致调试口失联?
连接日志如下
Connecting ... - Connecting via USB to probe/ programmer device 0 - Probe/ Programmer firmware: J-Link V9 compiled Dec 13 2022 11:14:50 - Probe/ Programmer S/N: 25952305 - Device "YTM32B1ME05" selected. - Target interface speed: 4000 kHz (Fixed) - VTarget = 3.288V - Found SW-DP with ID 0x6BA02477 - DPv0 detected - CoreSight SoC-400 or earlier - Scanning AP map to find all available APs - AP[0]: Stopped AP scan as end of AP map seems to be reached - Iterating through AP map to find AHB-AP to use - Attach to CPU failed. Executing connect under reset. - DPv0 detected - CoreSight SoC-400 or earlier - Scanning AP map to find all available APs - AP[0]: Stopped AP scan as end of AP map seems to be reached - Iterating through AP map to find AHB-AP to use - Could not find core in Coresight setup - Found SW-DP with ID 0x6BA02477 - Failed to power up DAP -
F Frankie 将这个主题标记为已解决
