  4. EVB_YTM32B1MD1x LINFlexD - UART cannot be achievable with baud rate 1Mbit/s
12 帖子 3 发布者 5.2k 浏览
  • tuanduongT 离线
    tuanduongT 离线
    tuanduong
    Hello supporters.
    Now we have been faced to the problem that is SW generation by YT tool.
    The LINFlexD - UART cannot be achievable baud rate 1Mbit/s
    Could you provide us examples or manual to configuration this one?
    链接文本[Linflexd_Uart_Interrupt_Demo.7z](无效文件格式,允许的格式有:.png, .jpg, .bmp, .txt, .webp, .webm, .mp4, .gif, .hex, .bin, .s19, .elf, .zip, .patch, .pdf, .yct, .jpeg)
    • xianghanX 在线
      xianghanX 在线
      The LinflexD peripheral clock source selects the PLL because the FIRC clock has a higher margin of error. When the UART baudrate increases, this can be affected, resulting in error frames.
      • 车友车行车 离线
        车友车行车 离线
        车友车行 YunTu
        Can you upload your YCT file for us to check
        • xianghanX 在线
          xianghanX 在线
          • xianghanX 在线
            xianghanX 在线
            • tuanduongT 离线
              tuanduongT 离线
              tuanduong
              The issue has been showed with baud rate.
              • tuanduongT 离线
                tuanduongT 离线
                tuanduong
                The YTM32B1MD1x LINFlexD -UART has not been supported with DMA.
                Do you have any idea to use UART with DMA? xianghan
                • xianghanX 在线
                  xianghanX 在线
                  LINFlexD UART模式使用DMA传输异常数据解决方案.pdf
                  • tuanduongT 离线
                    tuanduongT 离线
                    tuanduong
                    thanks for your information, I will try to do it.
                    • tuanduongT 离线
                      tuanduongT 离线
                      tuanduong
                      I have enabled DMA with LinflexD1_RX and LinflexD1_Tx trigger.
                      For transfer: when I use LinflexD1 as Uart send out data, DMA work normally.
                      For receive: When I use LinflexD1 as UArt receive data, DMA cannot work.
                      Phenomenon: data in LinflexD.Data[4] is detected by Linflex, but it cannot trigger DMA copy data to rx_buffer. It seem like the source trigger LinflexD1_Rx is not work. DO you have any idea about this situation? xianghan
                      • tuanduongT 离线
                        tuanduongT 离线
                        tuanduong
                        • tuanduongT 离线
                          tuanduongT 离线
                          tuanduong
                          Hello xianghan , you can check the reference manual, that is DMA mux table for YTM32B1MD1x do not support for UART DMA.
                          • tuanduongT 离线
                            tuanduongT 离线
                            tuanduong
                            Hello xianghan,
                            The issue has been showed. Thanks for your support.
                            LSNL
                            LSN
