  4. EVB_YTM32B1MD1x LINFlexD - UART cannot be achievable with baud rate 1Mbit/s
12 帖子 3 发布者 714 浏览
  • tuanduongT 离线
    tuanduongT 离线
    tuanduong
    Hello supporters.
    Now we have been faced to the problem that is SW generation by YT tool.
    The LINFlexD - UART cannot be achievable baud rate 1Mbit/s
    Could you provide us examples or manual to configuration this one?
    链接文本[Linflexd_Uart_Interrupt_Demo.7z](无效文件格式,允许的格式有:.png, .jpg, .bmp, .txt, .webp, .webm, .mp4, .gif, .hex, .bin, .s19, .elf, .zip, .patch, .pdf, .yct, .jpeg)
    • junhanhuangJ 在线
      junhanhuangJ 在线
      junhanhuang YunTu
      Can you upload your YCT file for us to check
        The LinflexD peripheral clock source selects the PLL because the FIRC clock has a higher margin of error. When the UART baudrate increases, this can be affected, resulting in error frames.
          • tuanduongT 离线
            tuanduongT 离线
            tuanduong
            The issue has been showed with baud rate.
            • tuanduongT 离线
              tuanduongT 离线
              tuanduong
              The YTM32B1MD1x LINFlexD -UART has not been supported with DMA.
              Do you have any idea to use UART with DMA? xianghan
                LINFlexD UART模式使用DMA传输异常数据解决方案.pdf
                • tuanduongT 离线
                  tuanduongT 离线
                  tuanduong
                  thanks for your information, I will try to do it.
                  • tuanduongT 离线
                    tuanduongT 离线
                    tuanduong
                    I have enabled DMA with LinflexD1_RX and LinflexD1_Tx trigger.
                    For transfer: when I use LinflexD1 as Uart send out data, DMA work normally.
                    For receive: When I use LinflexD1 as UArt receive data, DMA cannot work.
                    Phenomenon: data in LinflexD.Data[4] is detected by Linflex, but it cannot trigger DMA copy data to rx_buffer. It seem like the source trigger LinflexD1_Rx is not work. DO you have any idea about this situation? xianghan
                    • tuanduongT 离线
                      tuanduongT 离线
                      tuanduong
                      • tuanduongT 离线
                        tuanduongT 离线
                        tuanduong
                        Hello xianghan , you can check the reference manual, that is DMA mux table for YTM32B1MD1x do not support for UART DMA.
                        • tuanduongT 离线
                          tuanduongT 离线
                          tuanduong
                          Hello xianghan,
                          The issue has been showed. Thanks for your support.
                          YTBivY
                          YTBiv
                          yishui66Y
                          yishui66
                          WHQW
                          WHQ
                          wangweidongW
                          wangweidong
                          junhanhuangJ
                          junhanhuang
                          sqwS
                          sqw
                          WangPeiyingW
                          WangPeiying
                          QWQ
                          QW
                          Tiger987T
                          Tiger987
                          lswsjrmL
                          lswsjrm
                          LCL
                          LC
                          WalkerDW
                          WalkerD
                          jinyiJ
                          jinyi
                          luxiaoguoL
                          luxiaoguo
