  4. YTM32B1ME05的SPI速率问题
YTM32B1ME05的SPI速率问题
15 帖子 6 发布者 5.8k 浏览
  • yanglusiY 离线
    yanglusiY 离线
    yanglusi
    spi_state_t lpspi_MasterConfig0_State;
    const spi_master_config_t lpspi_MasterConfig0 = {
        .bitsPerSec=40000000U,
        .whichPcs=SPI_PCS0,
        .pcsPolarity=SPI_ACTIVE_LOW,
        .isPcsContinuous=false,
        .bitcount=8,
        .clkPhase=SPI_CLOCK_PHASE_1ST_EDGE,
        .clkPolarity=SPI_SCK_ACTIVE_HIGH,
        .lsbFirst=false,
        .transferType=SPI_USING_INTERRUPTS,
        .rxDMAChannel=1,
        .txDMAChannel=0,
        .callback=NULL,
        .callbackParam=NULL,
        .width=SPI_SINGLE_BIT_XFER,
    peripheral_clock_config_t clock_config0PeripheralClockConfig[4] = {
            .clkName = DMA_CLK,
            .clkGate = true,
            .divider = DIV_BY_1,
            .clkSrc = CLK_SRC_DISABLED,
            .clkName = GPIO_CLK,
            .clkGate = true,
            .clkSrc = CLK_SRC_PLL,
            .clkName = LINFlexD2_CLK,
            .clkGate = true,
            .clkName = SPI4_CLK,
            .clkGate = true,
            .divider = DIV_BY_3,
    const scu_config_t clock_config0ScuConfig = {
        .fircEnable = true,
        .fircDeepSleepEnable = false,
        .sircDeepSleepEnable = true,
        .sircStandbyEnable = true,
        .sircPowerDownEnable = true,
        .sysClkSrc = SCU_SYSTEM_CLOCK_SRC_PLL,
        .fxoscConfig =
                .enable = true,
                .bypassMode = false,
                .gainSelection = 5,
                .frequency = 24000000U,
        .sxoscConfig =
                .enable = false,
                .gainSelection = 0,
                .deepsleepEnable = false,
                .standbyEnable = false,
                .powerdownEnable = false,
                .frequency = 32768U,
        .pllConfig =
                .enable = true,
                .pllRefClock = SCU_PLL_REF_FXOSC_CLK,
                .pllFeedBackDiv = 10,
                .pllRefClkDiv = 1,
        .sysDiv = SCU_SYS_CLK_DIV_BY_1,
        .fastBusDiv = SCU_SYS_CLK_DIV_BY_1,
        .slowBusDiv = SCU_SYS_CLK_DIV_BY_3,
        .flashDiv = SCU_SYS_CLK_DIV_BY_3,
        .clockOutConfig =
                .enable = false,
                .source = SCU_CLKOUT_SEL_PLL_CLK,
                .divider = 1
    • yanglusiY 离线
      yanglusiY 离线
      yanglusi
      在 回复了 Diga 最后由 yanglusi 编辑
      Diga 早上好,我想配成40M的速率应该怎么配置,PLL时钟为120MHZ
        .bitsPerSec 的值应该跟实际 SCLK 成两倍的关系,可以试一下将 .bitsPerSec 的值改为 50MHz,实测应该是 25MHz
          你配置的SPI的功能时钟为 PLL/3=40M,这是无法配置20M以上的通信速率的。
          yanglusiY 1 条回复 最后回复
          • yanglusiY 离线
            yanglusiY 离线
            yanglusi
            • yanglusiY 离线
              yanglusiY 离线
              yanglusi
              image.png配置工具是不是有BUG,只能3分频,大于40MHZ就报错
              • WRW 离线
                WRW 离线
                WR YunTu
                这个不是bug,他要求输入的最大时钟频率是40Mhz
                • WRW 离线
                  WRW 离线
                  WR YunTu
                  你必须配置时钟频率小于等于40Mhz
                  • yanglusiY 离线
                    yanglusiY 离线
                    yanglusi
                    在 回复了 WR 最后由 编辑
                    WR 你好,我现在是配置等于输入时钟40Mhz,如何配置成SPI速率40MHZ,还有SPI的DMA发送最大字节数不能大于等于32768?
                      写于 最后由 run 编辑
                      最大的配置就是:
                      • IPC界面的SPI功能时钟最大到40MHz
                      • SPI总线上CLK 最大也就是20MHz(作为Master)
                      • 如果作为Slave,要求总线上CLK 最大是10MHz
                      发送最大字节,按照API应该是uint16_t, 65535字节
                      • yanglusiY 离线
                        yanglusiY 离线
                        yanglusi
                        在 回复了 run 最后由 编辑
                        run 实测是,DMA模式下大于等于32768就发不出来,中断模式就可以
                        FrankF 1 条回复 最后回复
                          在 回复了 yanglusi 最后由 编辑
                          yanglusi DMA TCNT为14为位,超出肯定不行的。54d90edf-d0f1-4900-aabd-c1564cf08599-image.png
                          使用DMA需要分开多次发送
                          • yanglusiY 离线
                            yanglusiY 离线
                            yanglusi
                            在 回复了 Frank 最后由 编辑
                            Frank OK,了解了
                            • yanglusiY 离线
                              yanglusiY 离线
                              yanglusi
                              支持DUAL SPI或者QSPI吗
                              • yanglusiY 离线
                                yanglusiY 离线
                                yanglusi
                                Frank 支持DUAL SPI或者QSPI吗
                                • yanglusiY 离线
                                  yanglusiY 离线
                                  yanglusi
                                  caitanyaC
                                  caitanya
                                  LongL
                                  Long
                                  skai353535S
                                  skai353535
                                  沈宇恒沈
                                  沈宇恒
                                  ljmL
                                  ljm
