  2. Blogs
  3. vscode如何配置C/C++环境,支持函数跳转和自动补全
已定时 已固定 已锁定 已移动 Blogs
vscode
5 帖子 4 发布者 8.0k 浏览
    YUNTU所有的VSCODE工程编译都是基于CMake来实现的,所有可以很容易的被各个IDE/插件识别
    VSCODE的C/C++插件可以用以下两种(任选其一即可),建议选择ClangD😊
    clangd 插件
    安装
    安装clangd,vscode会默认下载clangd-server,或者可以手动选择clangd的目录
    配置
    clangd的配置是每个workspace下的*.code-workspace文件里单独配置
        "folders": [
                "path": "."
        "settings": {
            "clangd.arguments": [
                "--compile-commands-dir=${workspaceFolder}/build",
                "--query-driver=${env:APPDATA}/yt_config_tool/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-gcc.exe"
    其中 --compile-commands-dir 是必须的,clangd会默认去搜索这个目录下的 compile_commands.json 文件,这个文件是工程经过cmake编译后产生的一个文件,
    格式大概如下:
      "directory": "C:/Users/Frankie/Downloads/ha0_dd/build",
      "command": "C:\\Users\\Frankie\\AppData\\Roaming\\yt_config_tool\\gcc-arm-none-eabi-10.3-2021.10\\bin\\arm-none-eabi-gcc.exe -DARMCM7_DP -DCORTEXM -DCPU_YTM32B1HA0 -DYTM32B1HA0 -IC:/Users/Frankie/Downloads/ha0_dd/board -IC:/Users/Frankie/Downloads/ha0_dd/platform/drivers/src/clock/YTM32B1Hx -IC:/Users/Frankie/Downloads/ha0_dd/platform/drivers/src/pins -IC:/Users/Frankie/Downloads/ha0_dd/platform/drivers/inc -IC:/Users/Frankie/Downloads/ha0_dd/platform/devices/common -IC:/Users/Frankie/Downloads/ha0_dd/platform/devices -IC:/Users/Frankie/Downloads/ha0_dd/platform/devices/YTM32B1HA0/include -IC:/Users/Frankie/Downloads/ha0_dd/platform/devices/YTM32B1HA0/startup -IC:/Users/Frankie/Downloads/ha0_dd/CMSIS/Core/Include -IC:/Users/Frankie/Downloads/ha0_dd/rtos/osif -mcpu=cortex-m7 -g -mlittle-endian -mthumb -specs=nosys.specs -Wall -Werror=all -Wno-error=comment -g -O1 -ffunction-sections -fdata-sections -Wno-error=unused-variable -Wno-error=unused-parameter -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-result -Wno-error=maybe-uninitialized -Wno-error=sign-compare -Wno-error=strict-aliasing -Wno-error=unknown-pragmas -Wno-error=format -fdiagnostics-color=always -o CMakeFiles\\GENERATED_CONFIG_TARGET.dir\\board\\clock_config.c.o -c C:\\Users\\Frankie\\Downloads\\ha0_dd\\board\\clock_config.c",
      "file": "C:\\Users\\Frankie\\Downloads\\ha0_dd\\board\\clock_config.c",
      "output": "CMakeFiles\\GENERATED_CONFIG_TARGET.dir\\board\\clock_config.c.o"
    记录了每一个c文件的搜索路径,编写选项等信息。
    --query-driver是可选测试,用于找到类似stdint.h 这种头文件,因为这些头文件在自己的工程下是不存在的。
    配置好后,就可以进行跳转了。
    效果
    数组自动加入索引
    函数参数名的显示
    代码自动补全
    C/C++ 插件
    因为这个插件不是很推荐,所以就简单解释一下🙄
    安装
    直接从vscode的扩展商店里安装即可
    配置
    c/c++的配置是每个workspace下的.vscode/c_cpp_properties.json文件里单独配置
        "env": {
            "PROJ_DIR": "${workspaceFolder}"
        "configurations": [
                "name": "YTM32B1HA0",
                "intelliSenseMode": "gcc-x64",
                "includePath": [
                    "${PROJ_DIR}/board",
                    "${PROJ_DIR}/platform/drivers/src/clock/YTM32B1Hx",
                    "${PROJ_DIR}/platform/drivers/src/pins",
                    "${PROJ_DIR}/platform/drivers/inc",
                    "${PROJ_DIR}/platform/devices/common",
                    "${PROJ_DIR}/platform/devices",
                    "${PROJ_DIR}/platform/devices/YTM32B1HA0/include",
                    "${PROJ_DIR}/platform/devices/YTM32B1HA0/startup",
                    "${PROJ_DIR}/CMSIS/Core/Include",
                    "${PROJ_DIR}/rtos/osif"
                "defines": [
                    "YTM32B1HA0",
                    "CPU_YTM32B1HA0"
                "cStandard": "c11",
                "cppStandard": "c++17",
                "compileCommands": "${workspaceFolder}/build/compile_commands.json",
                "browse": {
                    "path": [
                    "limitSymbolsToIncludedHeaders": true,
                    "databaseFilename": ""
                "configurationProvider": "ms-vscode.cmake-tools"
    也可以指定 compile_commands.json 文件
    • georgeG 离线
      georgeG 离线
      george YunTu
      而且这两个插件貌似会有冲突
      FrankieF 1 条回复 最后回复
        在 回复了 george 最后由 编辑
        george 是的
        • ZOUYIWENZ 离线
          ZOUYIWENZ 离线
          ZOUYIWEN
          安装C/C++ 插件还不行,然后又安装了clangd 插件还是不行
          • limanjiangL 离线
            limanjiangL 离线
            limanjiang YunTu
            我当时遇到类似问题,是参考这个链接解决的https://blog.51cto.com/u_15531854/5221004
            • jiankang_wangJ jiankang_wang 在 中 引用了 这个主题
            YTBivY
            YTBiv
