  4. SPI DMA example code
6 帖子 5 发布者 2.4k 浏览
  • dangho3D 离线
    dangho3D 离线
    dangho3
    Hello,
    I'm new to this toolchain/MCU. How can I get an example code or setup sequence to configure the SPI using DMA to transmit data?
    Thank you
      We download Spi_Master_Dma_Demo code and capture 4 pins shown following.
      13b1b477-1b83-4960-81c5-4ad242e01d28-img_v3_02hd_f1b5693e-39a7-4b60-8024-4e0863ffcf7g.jpg
      Maybe you should check pin connection or code if download.
      • qinzhaoQ 离线
        qinzhaoQ 离线
        qinzhao YunTu
        After installing the SDK in YT Config Tool.
        • dangho3D 离线
          dangho3D 离线
          dangho3
          I have done these steps, but the function "SPI_DRV_MasterTransfer" seem not working cause I have checked the signals on SPI2_SOUT. There isn't any signals
            • vonh2V 离线
              vonh2V 离线
              vonh2
              Hi, thanks for the information, the issue was due to my IAR setup.
              However, when using the example code. I observed that the PCS timing is not OK (Some time it triggers after the first clock edge) which caused the data corrupted.
                Hi, If the clock idle polarity is configured as high, during the SPI initialization will provide a low pulse to the clock pin (subsequent low pulses will not occur unless execute de-initilization and Init again). However, since the PCS (Peripheral Chip Select) signal is always activated after the first edge of the clock, it does not affect data transmission.
