  4. SPI DMA example code
已定时 已固定 已锁定 已移动 YTM32B1L系列
6 帖子 5 发布者 920 浏览
  • dangho3D 离线
    dangho3D 离线
    dangho3
    Hello,
    I'm new to this toolchain/MCU. How can I get an example code or setup sequence to configure the SPI using DMA to transmit data?
    Thank you
    • qinzhaoQ 离线
      qinzhaoQ 离线
      qinzhao YunTu
      After installing the SDK in YT Config Tool.
      • dangho3D 离线
        dangho3D 离线
        dangho3
        I have done these steps, but the function "SPI_DRV_MasterTransfer" seem not working cause I have checked the signals on SPI2_SOUT. There isn't any signals
          We download Spi_Master_Dma_Demo code and capture 4 pins shown following.
          13b1b477-1b83-4960-81c5-4ad242e01d28-img_v3_02hd_f1b5693e-39a7-4b60-8024-4e0863ffcf7g.jpg
          Maybe you should check pin connection or code if download.
          • vonh2V 离线
            vonh2V 离线
            vonh2
            Hi, thanks for the information, the issue was due to my IAR setup.
            However, when using the example code. I observed that the PCS timing is not OK (Some time it triggers after the first clock edge) which caused the data corrupted.
              Hi, If the clock idle polarity is configured as high, during the SPI initialization will provide a low pulse to the clock pin (subsequent low pulses will not occur unless execute de-initilization and Init again). However, since the PCS (Peripheral Chip Select) signal is always activated after the first edge of the clock, it does not affect data transmission.
              steelmate-02018S
              steelmate-02018
              yifeng_xieY
              yifeng_xie
