  3. YTM32B1MD1中的ld档案修改问题?
5 帖子 2 发布者 3.2k 浏览
  • abcbillA 离线
    abcbillA 离线
    abcbill
    • Copyright 2020-2025 Yuntu Microelectronics Co., Ltd.
    • All rights reserved.
    • SPDX-License-Identifier: BSD-3-Clause
    • @file yt_linker.ld
    • @brief
    /* MEMORY MAP /
    MEMORY
    IVT (RX) : ORIGIN = 0x0, LENGTH = 0x400
    TEXT (RX) : ORIGIN = 0x400, LENGTH = 0x7bc00
    DTC (RX) : ORIGIN = 0x7c000, LENGTH = 0x1000
    DTC_BACKUP (RX) : ORIGIN = 0x7d000, LENGTH = 0x1000
    INF (RX) : ORIGIN = 0x7e000, LENGTH = 0x1000
    INF_BACKUP (RX) : ORIGIN = 0x7f000, LENGTH = 0x1000
    IVT_RAM (RW) : ORIGIN = 0x1fff8000, LENGTH = 0x400
    STACK (RW) : ORIGIN = 0x20007c00, LENGTH = 0x400
    RAM (RW) : ORIGIN = 0x1fff8400, LENGTH = 0xf800
    SECTIONS */
    SECTIONS
    .IVT : {
        IVT_start = .;
        isr_vector_region_start = .;
        KEEP(*(.isr_vector))
        isr_vector_region_end = .;
        IVT_end = .;
    } > IVT
    .TEXT  : {
        TEXT_start = .;
        rodata_region_start = .;
        *(.rodata)
        *(.rodata*)
        rodata_region_end = .;
        text_region_start = .;
        *(.text)
        *(.text*)
        text_region_end = .;
        TEXT_end = .;
    } > TEXT
    .ARM  : {
        ARM_start = .;
        ARM.exidx_region_start = .;
        *(.ARM.exidx)
        *(.ARM.exidx*)
        ARM.exidx_region_end = .;
        ARM_end = .;
    } > TEXT
    CODE_RAM_rom_start_not_align = .;
    CODE_RAM_rom_start = CODE_RAM_rom_start_not_align + (CODE_RAM_rom_start_not_align % 4);
    CODE_RAM_rom_end = CODE_RAM_rom_start + CODE_RAM_ram_end - CODE_RAM_ram_start;
    DATA_RAM_rom_start_not_align = CODE_RAM_rom_end;
    DATA_RAM_rom_start = DATA_RAM_rom_start_not_align + (DATA_RAM_rom_start_not_align % 4);
    DATA_RAM_rom_end = DATA_RAM_rom_start + DATA_RAM_ram_end - DATA_RAM_ram_start;
    .DTC  (NOLOAD): {
        . = ALIGN(4096);
        DTC_start = .;
        . += 4096;
        . = ALIGN(4096);
        DTC_end = .;
    } > DTC
    .DTC_BACKUP  (NOLOAD): {
        . = ALIGN(4096);
        DTC_BACKUP_start = .;
        . += 4096;
        . = ALIGN(4096);
        DTC_BACKUP_end = .;
    } > DTC_BACKUP
    .INF  (NOLOAD): {
        . = ALIGN(4096);
        INF_start = .;
        . += 4096;
        . = ALIGN(4096);
        INF_end = .;
    } > INF
    .INF_BACKUP  (NOLOAD): {
        . = ALIGN(4096);
        INF_BACKUP_start = .;
        . += 4096;
        . = ALIGN(4096);
        INF_BACKUP_end = .;
    } > INF_BACKUP
    .IVT_RAM  : {
        . = ALIGN(1024);
        IVT_RAM_start = .;
        . += 0X400;
        IVT_RAM_end = .;
    } > IVT_RAM
    .STACK  : {
        STACK_start = .;
        . += 1024;
        STACK_end = .;
    } > STACK
    .BSS  (NOLOAD): {
        BSS_start = .;
        bss_region_start = .;
        *(.bss)
        *(.bss*)
        bss_region_end = .;
        BSS_end = .;
    } > RAM
    .CODE_RAM  : AT(CODE_RAM_rom_start) {
        . = ALIGN(4);
        CODE_RAM_ram_start = .;
        CODE_RAM_start = .;
        code_ram_region_start = .;
        *(.code_ram)
        code_ram_region_end = .;
        CODE_RAM_end = .;
        CODE_RAM_ram_end = .;
    } > RAM
    ASSERT((CODE_RAM_ram_end - CODE_RAM_ram_start) == (CODE_RAM_rom_end - CODE_RAM_rom_start), "Copy Section CODE_RAM Size non-aligned")
    .DATA_RAM  : AT(DATA_RAM_rom_start) {
        DATA_RAM_ram_start = .;
        DATA_RAM_start = .;
        *(.data)
        *(.data*)
        DATA_RAM_end = .;
        DATA_RAM_ram_end = .;
    } > RAM
    ASSERT((DATA_RAM_ram_end - DATA_RAM_ram_start) == (DATA_RAM_rom_end - DATA_RAM_rom_start), "Copy Section DATA_RAM Size non-aligned")
    IVT_memory_start = ORIGIN(IVT);
    IVT_memory_end = ORIGIN(IVT) + LENGTH(IVT);
    IVT_memory_size = LENGTH(IVT);
    TEXT_memory_start = ORIGIN(TEXT);
    TEXT_memory_end = ORIGIN(TEXT) + LENGTH(TEXT);
    TEXT_memory_size = LENGTH(TEXT);
    DTC_memory_start = ORIGIN(DTC);
    DTC_memory_end = ORIGIN(DTC) + LENGTH(DTC);
    DTC_memory_size = LENGTH(DTC);
    DTC_BACKUP_memory_start = ORIGIN(DTC_BACKUP);
    DTC_BACKUP_memory_end = ORIGIN(DTC_BACKUP) + LENGTH(DTC_BACKUP);
    DTC_BACKUP_memory_size = LENGTH(DTC_BACKUP);
    INF_memory_start = ORIGIN(INF);
    INF_memory_end = ORIGIN(INF) + LENGTH(INF);
    INF_memory_size = LENGTH(INF);
    INF_BACKUP_memory_start = ORIGIN(INF_BACKUP);
    INF_BACKUP_memory_end = ORIGIN(INF_BACKUP) + LENGTH(INF_BACKUP);
    INF_BACKUP_memory_size = LENGTH(INF_BACKUP);
    IVT_RAM_memory_start = ORIGIN(IVT_RAM);
    IVT_RAM_memory_end = ORIGIN(IVT_RAM) + LENGTH(IVT_RAM);
    IVT_RAM_memory_size = LENGTH(IVT_RAM);
    STACK_memory_start = ORIGIN(STACK);
    STACK_memory_end = ORIGIN(STACK) + LENGTH(STACK);
    STACK_memory_size = LENGTH(STACK);
    RAM_memory_start = ORIGIN(RAM);
    RAM_memory_end = ORIGIN(RAM) + LENGTH(RAM);
    RAM_memory_size = LENGTH(RAM);
    上面是项目中的ld檔,修改完后SPI的初始程序(下面所示)会一直在下面循环出不来(修改前是没问题的),请问有可能是什么原因呢?会不会是.bss档没清0呢?请问sample code清0的程序在那呢?
    while (spiState->rxCount != (uint16_t)0)
    /* Read the last word from the RX FIFO */
    if (SPI_GetStatusFlag(base, SPI_RX_DATA_FLAG))
    SPI_DRV_ReadRXBuffer(instance);
    • swustS 离线
      swustS 离线
      swust YunTu
      看下map文件,检查下text是不是溢出了
      • abcbillA 离线
        abcbillA 离线
        abcbill
        map 里显示:
        • TEXT:Origin 0x00000400,Length 0x0007BC00
        → 结束地址 = 0x0007C000
        map 里显示:
        • .TEXT output section 大小 0x7AC8,从 0x00000400 开始,到 0x00007EC8
        • .ARM output section 在 0x00007EC8,大小 0x8,到 0x00007ED0
        • .CODE_RAM 的 load address = 0x00007ED0
        • .DATA_RAM 的 load address = 0x00007FA8
        • DATA_RAM_rom_end = 0x000082C
        • Flash 实际用到大约 0x000082C9
        • swustS 离线
          swustS 离线
          swust YunTu
          这说明没溢出,那就看一下spiState被编到了哪个位置,如果在.code_ram 或 .data_ram,手动改一下Raminit1.c。
          • abcbillA 离线
            abcbillA 离线
            abcbill
            .bss.g_spiStatePtr
            0x1fff8c20 0x10 libGENERATED_SDK_TARGET.a(spi_shared_function.c.o)
            0x1fff8c20 g_spiStatePtr
            看起来是在.bss
            但奇怪的是我用原本的ld檔就不会出事,底下为原本的ld檔
            • @brief
            /* MEMORY MAP /
            MEMORY
            BOOT (RX) : ORIGIN = 0x400, LENGTH = 0x7c00
            SECTIONS */
            SECTIONS
            .IVT : {
                IVT_start = .;
                IVT_end = .;
            } > IVT
            .TEXT  : {
                TEXT_start = .;
                *(.rodata)
                *(.rodata*)
                *(.text)
                *(.text*)
                TEXT_end = .;
            } > BOOT
            .ARM  : {
                ARM_start = .;
                *(.ARM.exidx)
                *(.ARM.exidx*)
                ARM_end = .;
            } > BOOT
            .IVT_RAM  : {
                . = ALIGN(1024);
                IVT_RAM_start = .;
                . += 0X400;
                IVT_RAM_end = .;
            } > IVT_RAM
            .STACK  : {
                STACK_start = .;
                . += 1024;
                STACK_end = .;
            } > STACK
            .BSS  (NOLOAD): {
                BSS_start = .;
                *(.bss)
                *(.bss*)
                bss_region_end = .;
                BSS_end = .;
            } > RAM
                . = ALIGN(4);
                CODE_RAM_start = .;
                *(.code_ram)
                CODE_RAM_end = .;
            } > RAM
                DATA_RAM_start = .;
                *(.data)
                *(.data*)
                DATA_RAM_end = .;
            } > RAM
            BOOT_memory_start = ORIGIN(BOOT);
            BOOT_memory_end = ORIGIN(BOOT) + LENGTH(BOOT);
            BOOT_memory_size = LENGTH(BOOT);
