  2. Announcements
  3. MCAL Release Notes
  4. YTM32B1MD2_0_9_0 Release Notes
已定时 已固定 已锁定 已移动 MCAL Release Notes
1 帖子 1 发布者 2.7k 浏览
    Overview
    YUNTU MCAL(Microcontroller Abstract Layer) software package is designed by YTMicro AE team to support customers on AUTOSAR compliant application software development. The YUNTU MCAL is developed according to the AUTOSAR CP Release v4.4.0 standard.
    Package Name Version Release Date
    YTM32B1MD2_0_9_0 0_9_0 2025-08-29
    Support Toolchains
    YUNTU MCAL software package release are tested and validated with the following toolchains/IDE:
    Recommended Configuration Tool:
    • YCT(Yuntu Config Tool) v2.7.7 or higher version
    Tips: It can be downloaded from YTMicro Account or updated from the installed older version YCT.
    Recommended IDE/Compilers:
    • ARM Keil v5.36 or higher version IDE
    • IAR v8.40 or higher version IDE
    • VSCode v1.80 or higher version IDE with Ninja, CMake and GCC/IAR/Keil as compiler
    • GCC for ARM v10.3 or higher version
    Recommended debuger:
    • SEGGER J-INK v9.2 or higher hardware + v6.96 or higher software/driver with required YTM32B1ME05 and YTM32B1MD14 patch installed.
    Release List
    • [New]-[CddDma]-[0] Adapt the CddDma to MD24
    • [New]-[Pwm]-[0] add Pwm support for MD24
    • [New]-[Gpt]-[0] add Gpt support for MD24
    • [New]-[Port]-[0] add Port support for MD24
    • [New]-[Mcu]-[0] Add Mcu support for MD24
    • [New]-[Icu]-[0] MD24 Icu MCAL Adaptation
    • [New]-[Icu]-[0] Add MD24 Icu_Wakeup demo
    • [New]-[Fls]-[0] Add Fls support for MD24
    • [New]-[CddUart]-[0] add CddUart support for MD24
    • [Opt]-[CddUart]-[1] Enable FIFO to optimize the issue of CddUart frequently entering interrupts for improved efficiency.
    • [New]-[Ocu]-[0] Add Ocu support for MD24
    • [New]-[Can]-[0] Add Can support for MD24
    • [New]-[Lin]-[0] add Lin support for MD24
    • [New]-[Dio]-[0] add Dio support for MD24
    • [New]-[Fee]-[0] Add Fee support for MD24
    • [New]-[Adc]-[0] Add Adc and CddTrg support for MD24
    • [New]-[CddI2c]-[0] Add I2c support for MD24
    • [New]-[Crc]-[0] add Crc support for MD24
    • [New]-[Spi]-[0] Add spi support for MD2
    • [New]-[Wdg]-[0] Add Wdg support for MD24
    • [Demo]-[Mcal]-[0] Add example of CddDma CddI2c and Spi for MD24
    • [Demo]-[Mcal]-[0] Add EVB Demo for MD24
    • [New]-[Crypto]-[0] Add Crypto support for MD24
    Annex
    Release list naming rule
    Each release list item shall contain the following elements:
    [Type] - [Sub-Type/Module] - [Effect_Level] [Brief/Overview Description][Reference/Details Link]
    • [Type]
      • Fix: Bug fixes / issue resolution
      • Opt: Code performance optimization
      • New: New feature implementation
      • Demo: Example / demonstration project
      • Doc: Documentation updates
    • [Sub-Type/Module]
      • MCAL: Mcu/Dio/Port/Can/Lin/Spi/Gpt/Pwm/Adc/Icu/Ocu/Fls/Fee/Platform/CddUart/CddSai/CddPpu/CddI2c/CddDma/CddTrg
      • SafLib: CorTst/RamTst/FlsTst/IntTst/WdgTst/CrcTst/DmaTst/PpuTst/EfmTst/StkTst/EccTst/FmuTst
      • GUI: the YCT XDM config GUI update for the MCAL/SafLib SW package, the YCT Vue config GUI update for the SDK/Middleware SW package(no code change/modification)
    • [Effect_Level]
      • 0: No effect to the old version SW/project
      • 1: Recommend but optional to update, for example the performance optimization
      • 2: Must update for a specified SW module/components if the customer application used the related feature/functionality
      • 3: Must update for a specified SW module/components if it is used
      • 4: Must update if the SDK/MCAL/SafLib package is used
    • [Brief/Overview Description]
      • [Type] = Fix: Fixed the xxx issue/bug of the yyy HW/SW functionality/feature caused by condition
      • [Type] = Opt: Optimized the performance of the yyy HW/SW functionality/feature
      • [Type] = New: Added the new feature/functionality support of xxx
      • [Type] = Demo: added/updated the demo project: brief description
    • [Reference/Details Link]
      • Errata: give out the detailed Errata number
      • others: the link to the bug/issue analysis, it can be:
        • Link to a YUNTU form post [if it is derived from a FAE/customer feedback]
        • Link to a YUNTU form blog [if it is derived from a YUNTU form blog discussion]
    Disclaimer
    Copyright and Contact Information
    YTMicro and its subsidiaries reserve the right to change, correct, enhance, modify and improve YTMicro products or this document at any time without notice. Before placing an order, purchasers should obtain and understand the latest relevant information about the products. YUNTU's products are sold according to YUNTU team and sales conditions at the time of order confirmation. Purchasers have the sole responsibility for selecting, choosing and using YUNTU products, and YUNTU has no responsibility for assisting purchasers in product design and application. YUNTU does not grant any express or implied license to any intellectual property herein. Resale of YUNTU products with information different from that described herein will make any warranty of YUNTU for such product void. YTMicro and YTMicro logo are trademarks of YTMicro. All other product or service names are the property of their respective owners. The information in this document replaces and supersedes any previously provided information in any prior version of this document. © 2020 - 2025 YUNTU Microelectronics co.,ltd. All rights reserved.
    Contact us: Website: www.ytmicro.com.
    • FrankieF Frankie 从 中的 MCAL Private Issues 移动了该主题
    swordsS
    swords
