  4. MD2 etmr0配置成输出比较异常问题
2 帖子 1 发布者 759 浏览
  • xufengkunX 离线
    xufengkunX 离线
    xufengkun
    MD2 etmr0一共配置了6个通道的输出比较,初始化时给一个时间去触发中断,进入中断后安排一段时间后再进入中断,如此循环,测试发现一共6个通道,有2个通道CH0,CH1正常,有4个通道CH4,CH5,CH6,CH7会停止进中断,同样的代码移植到ME0里没有问题!```
    code_text
    • xufengkunX 离线
      xufengkunX 离线
      xufengkun
      初始化:
      eTMR_DRV_Deinit(eTMR_INST_oc);
      eTMR_DRV_Init(eTMR_INST_oc, &eTMR_Config, &etmrState_oc);
      eTMR_DRV_InitOutputCompare(eTMR_INST_oc, &eTMR_OutputCmpParamConfig);
      INT_SYS_InstallHandler(eTMR0_Ch0_Ch1_IRQn, eTMR0_Ch0_Ch1_IRQHandler_OutputCompare, NULL);
      INT_SYS_InstallHandler(eTMR0_Ch4_Ch5_IRQn, eTMR0_Ch4_Ch5_IRQHandler_OutputCompare, NULL);
      INT_SYS_InstallHandler(eTMR0_Ch6_Ch7_IRQn, eTMR0_Ch6_Ch7_IRQHandler_OutputCompare, NULL);
      /* set priority */
      INT_SYS_SetPriority(eTMR0_Ch0_Ch1_IRQn,2);
      INT_SYS_SetPriority(eTMR0_Ch4_Ch5_IRQn,2);
      INT_SYS_SetPriority(eTMR0_Ch6_Ch7_IRQn,2);
      /* Enable IRQ in NVIC level */
      INT_SYS_EnableIRQ(eTMR0_Ch0_Ch1_IRQn);
      INT_SYS_EnableIRQ(eTMR0_Ch4_Ch5_IRQn);
      INT_SYS_EnableIRQ(eTMR0_Ch6_Ch7_IRQn);
      eTMR0->INTE |= eTMR_INTE_CH0IE_MASK;
      eTMR0->INTE |= eTMR_INTE_CH1IE_MASK;
      eTMR0->INTE |= eTMR_INTE_CH4IE_MASK;
      eTMR0->INTE |= eTMR_INTE_CH5IE_MASK;
      eTMR0->INTE |= eTMR_INTE_CH6IE_MASK;
      eTMR0->INTE |= eTMR_INTE_CH7IE_MASK;
      eTMR_DRV_Enable(eTMR_INST_oc);
      中断:
      uint32_t statusFlags = 0U;
      statusFlags = g_etmrBase[eTMR0_INST_PWM]->STS; //read channel status flags.
      if( (statusFlags&eTMR_STS_CH6F_MASK) == eTMR_STS_CH6F_MASK ) //channel2
      g_etmrBase[eTMR0_INST_PWM]->STS = eTMR_STS_CH6F_MASK;
      	//g_etmrBase[eTMR0_INST_PWM]->SYNC |= eTMR_SYNC_LDOK_MASK|eTMR_SYNC_SWTRIG_MASK;
          //点火2
          OC_IGN2_OnInterrupt(g_etmrBase[eTMR0_INST_PWM]->CNT);
      if( (statusFlags&eTMR_STS_CH7F_MASK) == eTMR_STS_CH7F_MASK )
      	g_etmrBase[eTMR0_INST_PWM]->STS = eTMR_STS_CH7F_MASK;
      	//点火1
          OC_IGN_OnInterrupt(g_etmrBase[eTMR0_INST_PWM]->CNT);
      void OC_IGN_OnInterrupt(uint32_t c_val)//ch7
      switch(MCU_PWMSignal_7_PD10_st)
      case 0:
      break;
      case 1:
      dri_FUN_oc_ch7_Trig(500,1);
      MCU_PWMSignal_7_PD10_st = 2;
      break;
      case 2:
      dri_FUN_oc_ch7_Trig(500,0);
      MCU_PWMSignal_7_PD10_st = 1;
      break;
      default:
      break;
      触发:
      void dri_FUN_oc_ch0_Trig(uint32_t time, uint32_t ST)
      #if (M_OC_Mode == M_OC_out_PWM_Mode)
      uint32_t val0_set_v;
      eTMR_Type * const etmrBase = g_etmrBase[eTMR_INST_oc];
      eTMR_DRV_ClearLdok(eTMR_INST_oc);
      val0_set_v = etmrBase->CNT + time;
      if( val0_set_v >= (etmrBase->MOD+1) )
      val0_set_v = val0_set_v - (etmrBase->MOD+1); //correct new val0
      eTMR_DRV_UpdateOutputCompareChannel(eTMR_INST_oc,M_MCU_ocSignal_0_ch,val0_set_v,val0_set_v,ST,ST,1);
      #endif
      沈宇恒沈
      沈宇恒
      jiankang_wangJ
      houjun_xiaoH
      houjun_xiao
      RuiXuR
      RuiXu
      JETTJ
      JETT
      Epiphany47E
      Epiphany47
      zxlllZ
      zxlll
      nuyoahN
      nuyoah
