  4. YTM32B1MD1 Temperature Sensor - What is TSC register?
6 帖子 2 发布者 3.6k 浏览
  • nguyan2N 离线
    nguyan2N 离线
    nguyan2
    Hi everyone,
    I’m trying to read the MCU temperature from the internal temperature sensor of the YTM32B1MD1.
    According to the Reference Manual, it says I need to read the C value from the TSC register in the ADC. But I couldn’t find any register named TSC in the ADC register group, or anywhere else in the document.
    Has anyone worked with this before? Is it a typo in the manual, or where can I find the TSC register? I'm using the RM Rev. 1.3.
    Thanks in advance!
      Currently,you can get some reference from the YTM32B1MC0 reference manual.
      The next version of the YTM32B1MD1 reference manual may update the relevant registers.
      nguyan2N 1 条回复 最后回复
        You can refer to the attachment below: YTM32B1MD1_TempSensorDemo
        YTM32B1MD1_TempSensorDemo.zip
        nguyan2N 1 条回复 最后回复
        • nguyan2N 离线
          nguyan2N 离线
          nguyan2
          在 回复了 run 最后由 编辑
          run 在 YTM32B1MD1 Temperature Sensor - What is TSC register? 中说:
          Thank you for your repy. Can I ask how did you obtain this example or which document did you follow?
            nguyan2N 1 条回复 最后回复
            • nguyan2N 离线
              nguyan2N 离线
              nguyan2
              在 回复了 run 最后由 编辑
              Hello, one more question from my side. How could I know if the coefficient I readback is correct or not?
              I refered from your example code and got the coefficient value was 386. Is it correct or not?
              Thanks in advance!
                Generally, if the reading is not entirely FF, it is correct. You can use a temperature sensor at room temperature to measure the actual temperature. If it is close to the ambient temperature, it confirms that its COEFF is correct.
                caitanyaC
                caitanya
                SANzyS
                SANzy
                swordsS
                swords
