  4. 测试LIN通讯,偶发出现报文发送中断的情况,代码是Demo例程集成的
1 帖子 1 发布者 1.1k 浏览
  • YanglzY 离线
    YanglzY 离线
    Yanglz
    微信图片_20250414155155.jpg static void Lin_CallbackHandler(uint32_t instance, lin_state_t *lin_State)
    (void)instance;
    switch (lin_State->currentEventId)
        case LIN_PID_OK:
            /* Set frame header timeout */
            LIN_DRV_SetTimeoutCounter(INST_LIN, TIMEOUT);
            /* If PID is FRAME_MASTER_RECEIVE_DATA, master node will receive data */
            if (FRAME_MASTER_RECEIVE_DATA == lin_State->currentId)
                LIN_DRV_SendFrameData(INST_LIN, txBuff, sizeof(txBuff));
                /* Call to Send Frame DATA Function */
            /* If PID is FRAME_SLAVE_RECEIVE_DATA, salve node will receive data from master node */
            else if (FRAME_SLAVE_RECEIVE_DATA == lin_State->currentId)
                LIN_DRV_ReceiveFrameData(INST_LIN, rxBuff, sizeof(rxBuff));
            else if (FRAME_Dcm_Response_DATA == lin_State->currentId)
            	if(txDcmFlag == Dcm_Req||txDcmFlag == Dcm_Busy)
            		LIN_DRV_SendFrameData(INST_LIN, txDcmBuff, sizeof(txBuff));
            		txDcmFlag = Dcm_Busy;
            	else
            	    /* Go to idle mode */
    				LIN_DRV_GotoIdleState(INST_LIN);
    	   else if (FRAME_Dcm_Request_DATA == lin_State->currentId)
    		   LIN_DRV_ReceiveFrameData(INST_LIN, rxDcmBuff, sizeof(rxBuff));
    		   rxDcmFlag = Dcm_Req;
            /* If PID is FRAME_GO_TO_SLEEP, salve node will go to sleep mode */
            else if (FRAME_GO_TO_SLEEP == lin_State->currentId)
                sleepSignalFlag = true;
            else
            break;
        case LIN_PID_ERROR:
            break;
        case LIN_TX_COMPLETED:
        		 if( Dcm_Busy == txDcmFlag)
        			txDcmFlag = Dcm_Finished;
        	        ISO15765_TransmitConfirm();
        	  else
        		  txCompFlag = true;
            break;
        case LIN_RX_COMPLETED:
    		   rxDcmFlag = Dcm_Busy;
    	   else
    		   rxCompFlag = true;
            break;
        case LIN_CHECKSUM_ERROR:
        case LIN_READBACK_ERROR:
        case LIN_FRAME_ERROR:
        case LIN_RECV_BREAK_FIELD_OK:
            /* Set response timeout */
            break;
        case LIN_WAKEUP_SIGNAL:
            /* Set wakeup signal flag */
            wakeupSignalFlag = true;
            break;
        case LIN_SYNC_ERROR:
        case LIN_BAUDRATE_ADJUSTED:
        case LIN_NO_EVENT:
        case LIN_SYNC_OK:
        default:
            /* do nothing */
            break;
    跑了16个小时左右,出现了7次响应服务错误。
