  4. FlexCAN初始化注意事项
FlexCAN初始化注意事项
9 帖子 5 发布者 7.0k 浏览
    SDK中FlexCAN初始化注意事项:
    如果采用中断方式收发,注册回调函数FLEXCAN_DRV_InstallEventCallback和FLEXCAN_DRV_InstallErrorCallback,以及mailbox或fifo,滤波器的初始化需要放在启动接收函数之前
    例如,以下为不太合理的邮箱初始化程序:
    /* Config rx messages mailbox */
            for (index = 0; index < Appl_Can_NodeRxMsgCount[canNodeIndex]; index++)
                /* Config rx buffer */
                status = CAN_ConfigRxBuff(&can_pal_instance,
                                          index,
                                          &Appl_Can_StdIdBuffCfg,
                                          (uint32_t)Appl_Can_NodeRxMsgPtr[canNodeIndex][index].id);
                /* start to receive message */
                status = CAN_Receive(&can_pal_instance,
                                     index,
                                     (can_message_t *)&Appl_Can_NodeRxMsgPtr[canNodeIndex][index]);
    应更改为:
                                          index,
                                     index,
    EkkoE 1 条回复 最后回复
      写于 最后由 run 编辑
      配置顺序:
      1. 先配置所有需要配置的邮箱的独立掩码(如果需要):
        FLEXCAN_DRV_SetRxMaskType(instance, FLEXCAN_RX_MASK_INDIVIDUAL);
        FLEXCAN_DRV_SetRxIndividualMask();
      2. 再配置所有需要配置的邮箱Mailbox
        FLEXCAN_DRV_ConfigRxMb();
      3. 安装中断回调函数
        FLEXCAN_DRV_InstallEventCallback();
        FLEXCAN_DRV_InstallErrorCallback();
      4. 最后启动接收(使能邮箱中断)
        FLEXCAN_DRV_Receive();
      示例:
      /* Set the individual mask type */
      FLEXCAN_DRV_SetRxMaskType(CAN_INST, FLEXCAN_RX_MASK_INDIVIDUAL);
      /* Set standard individual mask, bit 0-11 Optional, this example STD_ID 0x700U - 0x7FFU will be receive */
      FLEXCAN_DRV_SetRxIndividualMask(CAN_INST, FLEXCAN_MSG_ID_STD, RX_STD_MAILBOX, 0xF00U);
      /* Set extended individual mask, bit 0-28 Optional, this example EXD_ID 0x18C00100U - 0x18C001FFU will be receive */
      FLEXCAN_DRV_SetRxIndividualMask(CAN_INST, FLEXCAN_MSG_ID_EXT, RX_EXT_MAILBOX, 0x1FFFFF00U);
      /* After configure all individual masks, then congigure rx mailbox */
      status |= FLEXCAN_DRV_ConfigRxMb(CAN_INST, RX_STD_MAILBOX, &rxMbStdInfo, RX_STD_MSG_ID);
      status |= FLEXCAN_DRV_ConfigRxMb(CAN_INST, RX_EXT_MAILBOX, &rxMbExtInfo, RX_EXTMSG_ID);
      /* Install rx callback */
      FLEXCAN_DRV_InstallEventCallback(CAN_INST, DRV_CAN_RxEventCall, NULL);
      FLEXCAN_DRV_InstallErrorCallback(CAN_INST, DRV_CAN_ErrorCall, NULL);
      /* Start receiving data in RX_STD/EXT_MAILBOX. */
      status |= FLEXCAN_DRV_Receive(CAN_INST, RX_STD_MAILBOX, &rxStdMsg);
      status |= FLEXCAN_DRV_Receive(CAN_INST, RX_EXT_MAILBOX, &rxExtMsg);
      • qinhongkuiQ 离线
        qinhongkuiQ 离线
        qinhongkui
        楼主有CAN中断接收的demo吗?
        YQHY 2 条回复 最后回复
        -1
        • YQHY 离线
          YQHY 离线
          YQH YunTu
          在 回复了 qinhongkui 最后由 编辑
          qinhongkuiQ 1 条回复 最后回复
          • qinhongkuiQ 离线
            qinhongkuiQ 离线
            qinhongkui
            在 回复了 YQH 最后由 qinhongkui 编辑
            YQH 非常谢谢
            • EkkoE 离线
              EkkoE 离线
              在 回复了 yt0069 最后由 编辑
              yt0069 如果注册回调函数放在接收函数之后,可能会出现什么情况,目前有客户这样做,会偶发出现固定接收不到某一个ID,我帮他修改初始化流程之后,目前还没复现,想确认一下原理。
              YQHY 1 条回复 最后回复
              • YQHY 离线
                YQHY 离线
                YQH YunTu
                在 回复了 Ekko 最后由 编辑
                Ekko 客户是什么用法,是在总线已有其他节点发报文的情况下再接入自己的控制器时出现某个报文接收不到的情况吗
                EkkoE 1 条回复 最后回复
                • EkkoE 离线
                  EkkoE 离线
                  在 回复了 YQH 最后由 编辑
                  YQH 目前测试情况是通过CANOE一直在发报文,MCU重复上电,偶发出现
                  • YQHY 离线
                    YQHY 离线
                    YQH YunTu
                    qinhongkui
                    CAN_INT_Demo.zip
                    • yt0069Y yt0069 在 中 引用了 这个主题
                      写于 最后由 run 编辑
                      配置顺序:
                      3. 安装中断回调函数
                      4. 最后启动接收(使能邮箱中断)
                      示例:
                      文洪奎文
                      文洪奎
                      LiftRightL
                      LiftRight
                      zhaoQZ
                      zhaoQ
