  4. ADC self-test
ADC self-test
9 帖子 2 发布者 4.6k 浏览
  • vonh2V 离线
    vonh2V 离线
    vonh2
    Hi, for the ADC module, does YTM32B1LE0 has any build-in seft-test?
    I acknowledged the analog watchdog to monitor the ADC range but it not my case where I want to check if the ADC conversion is correct. My intention is that I can connect an DAC output pin to an ADC input pin to read the conversion result and compare with the configured DAC output to verify the ADC correctness. However, I have to modify my hardware PCB design. So is there any method, build-in feature to fulfill this self-test or if the MCU has any others mechanism to do the ADC self-test please let me know.
    Thank you
    • xianghanX 在线
      xianghanX 在线
      This register has not been developed for customers. If there is a high requirement for functional safety, self checking can be achieved through this register.
      • xianghanX 在线
        xianghanX 在线
        As shown in the figure
        You can choose the internal channel as the ADC module self-test
        • vonh2V 离线
          vonh2V 离线
          vonh2
          Thanks for the information,
          However, in my YTM32B1LE0x Reference Manual (revision 1.7), there is no information about the PCU memory map. Could you tell me which document contain the shared picture?
          Thank you
          • xianghanX 在线
            xianghanX 在线
            • vonh2V 离线
              vonh2V 离线
              vonh2
              Hi, do you have any plan to introduce this feature in your next revision of the YTM32B1LE0x Reference Manual? if yes may I know when? Thank you
              • vonh2V 离线
                vonh2V 离线
                vonh2
                Hello, could you share me some information regarding the above information? Thank you
                • xianghanX 在线
                  xianghanX 在线
                  Hello ,Currently, there are no plans to update this ADC self-test information.
                  • vonh2V 离线
                    vonh2V 离线
                    vonh2
                    Hello, since we need to configure PCU register to connect VDD15 to ADC CH23, do we need to configure PCU register to connect VSS15 to ADC CH22?Thank you
                    • xianghanX 在线
                      xianghanX 在线
                      Not need
                      JETTJ
                      JETT
                      zhaiZ
                      zhai
