  4. 为什么YTM32B1LE05 canfd发送出去的数据zlg usbcanfd-200u显示的是canfd加速,不是标准的canfd,请问怎么更改
已定时 已固定 已锁定 已移动 YTM32B1L系列
1 帖子 1 发布者 1.2k 浏览
  • ethanE 离线
    ethanE 离线
    ethan
    芯片
    YTM32B1LE05 48MHz, 16KB SRAM MCU based on ARM Cortex-M0+ Core
    48pin LQFP
    时钟 40M
    代码如下:
    const can_user_config_t can_pal_Config = {
    .maxBuffNum = 7UL,
    .mode = CAN_NORMAL_MODE,
    .peClkSrc = CAN_CLK_SOURCE_OSC,
    .enableFD = true,
    .payloadSize = CAN_PAYLOAD_SIZE_64,
    .nominalBitrate = {
    .propSeg = 5UL,
    .phaseSeg1 = 0UL,
    .phaseSeg2 = 1UL,
    .preDivider = 3UL,
    .rJumpwidth = 1UL},
    .dataBitrate = {.propSeg = 2UL, .phaseSeg1 = 2UL, .phaseSeg2 = 1UL, .preDivider = 0UL, .rJumpwidth = 1UL},
    .extension = NULL};
    status_t Can_Board_init()
    uint32_t index;
    uint8_t canid = 0x01;
    status_t status = STATUS_SUCCESS;
    /* canfd init /
    status |= CAN_Init(&can_pal_instance, &can_pal_Config);
    status = CAN_InstallEventCallback(&can_pal_instance, can0_mb_CallBack, NULL);
    canid = CanId_read();
    Configure RX buffer with index RX_MAILBOX /
    for (index = 0; index < CAN0_RX_MSG_COUNT; index++)
    can0_RxMsgs[index].id = (can0_RxMsgs[index].id & 0xFF0) | (canid & 0x0F);
    can0_TxMsgs[index].id = (can0_TxMsgs[index].id & 0xFF0) | (canid & 0x0F);
    Config rx buffer /
    status = CAN_ConfigRxBuff(&can_pal_instance,
    index,
    &can0_BuffCfg,
    (uint32_t)can0_RxMsgs[index].id);
    start to receive message /
    status = CAN_Receive(&can_pal_instance,
    index,
    (can_message_t )&can0_RxMsgs[index]);
    Configure TX buffer with index TX_MAILBOX
    for (index = 0; index < CAN0_TX_MSG_COUNT; index++)
    /* Config tx buffer */
    status = CAN_ConfigTxBuff(&can_pal_instance,
    index + CAN0_RX_MSG_COUNT,
    &can0_BuffCfg);
    return status;
    can和的反馈截图如下:
    lxhxssL
    秦伟秦
    秦伟
    JETTJ
    JETT
