  4. Fail to connect to erase chip YTM32B1LE05 via J-Flash V8.10
已定时 已固定 已锁定 已移动 YTM32B1L系列
4 帖子 2 发布者 2.5k 浏览
  • TungDoT 离线
    TungDoT 离线
    TungDo
    I can not to flash or erase chip via J-Flash V8.10, please help me
      Can you paste the complete log from the jflash log window?
      Maybe you can try to erase the program on YUNTU official EVB board.
      • TungDoT 离线
        TungDoT 离线
        TungDo
        Application log started
        • J-Flash V8.10g (J-Flash compiled Nov 14 2024 08:50:03)
        • JLinkARM.dll V8.10g (DLL compiled Nov 14 2024 08:48:50)
          Reading flash device list [C:\Data_DevTools\SEGGER\JLink_V8\JLink_V810g\ETC/JFlash/Flash.csv] ...
        • List of flash devices read successfully (451 Devices)
          Reading MCU device list ...
        • List of MCU devices read successfully (11530 Devices)
          Creating new project ...
        • New project created successfully
          Erasing chip ...
        • Connecting ...
        • Connected successfully
        • 260 sectors, 2 ranges, 0x0 - 0x1FFFF, 0x10000000 - 0x100007FF
        • Start of determining flash info (Bank 0 @ 0x00000000)
        • End of determining flash info
        • Flash bank info:
        • 256 * 512 bytes @ 0x00000000
        • Start of preparing flash programming
        • End of preparing flash programming
        • Start of determining dirty areas in flash cache
        • End of determining dirty areas
        • CPU is running at 7304 kHz.
        • Start of erasing chip
        • ERROR: PC of target system has unexpected value after erasing chip. (PC = 0xFFFFFFFE)!
          ---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
          PC = FFFFFFFE
          Current: R0 = 40020000, R1 = 00000010, R2 = 00000080, R3 = 0F05FFEE
          R4 = 10000200, R5 = 23A4B2FF, R6 = E2705CA9, R7 = E149679D
        • End of erasing chip
        • ERROR: Erase failed
        • Start of restoring
        • End of restoring
        • ERROR: Failed to erase chip
          Disconnecting ...
        • Disconnected
        • TungDoT 离线
          TungDoT 离线
          TungDo
          this is JFlash log window, I has been connected but can not to erase or test chip.
