  4. 重新启动后adc采样概率性所有值为0,请问怎么解决
5 帖子 2 发布者 2.8k 浏览
  • ethanE 离线
    ethanE 离线
    ethan
    因为同时采样了芯片内部的温度adc,理论上不能所有adc的值都是0,请帮忙看看
    代码如下:
    typedef struct
    // ADC_data ADC_Channel; //ADC²ÉÑùͨµÀ-Ó¦ÓÃ
    volatile unsigned char ADC_SamplingChannel; // ADC²ÉÑùͨµÀ
    volatile unsigned char ADC_CurrentSamplingChannel; // ADC²ÉÑùͨµÀ
    volatile unsigned short ADC_ConversionBuff[ADCALLCHANNEL_DEPTH]; // ADC²ÉÑùÊý¾Ý»º´æ
    volatile unsigned int ADC_ConversionCount; // ADCͨµÀÇл»ÑÓʱ¼ÇÊý
    volatile unsigned char ADC_ConversionFlag; // ADCµ¥Í¨µÀ¶à´Î²ÉÑùÍê³É±êʶ
    } ADC_Control;
    ADC_Control ADC0_Control;
    const adc_converter_config_t adcInitConfig = {
    .clockDivider = 0U,
    .startTime = 64,//0x20,
    .sampleTime = 10,//0xFF,//0x2C,
    .overrunMode = false,
    .autoOffEnable = false,
    .waitEnable = false,
    .trigger = ADC_TRIGGER_HARDWARE,
    .align = ADC_ALIGN_RIGHT,
    .resolution = ADC_RESOLUTION_12BIT, //²ÉÑùʱ¼ä=£¨ADC_RESOLUTION_12BIT+2+sampleTime)*²ÉÑùʱÖÓÖÜÆÚ
    .dmaWaterMark = ADC_SEQUENCE_LENGTH - 1,
    .dmaEnable = true,
    .compareConfig = {
    .compareEnable = false,
    .compareAllChannelEnable = false,
    .compHigh = 0x00U,
    .compLow = 0x00U,
    .compIntEnable = false
    .sequenceConfig = {
    .channels = {
    ADC_INPUTCHAN_EXT9,
    ADC_INPUTCHAN_EXT3,
    ADC_INPUTCHAN_EXT1,
    ADC_INPUTCHAN_EXT0,
    0x10, //MCU ÄÚÖÃζȲɼ¯
    // ADC_INPUTCHAN_EXT9,
    // ADC_INPUTCHAN_EXT3,
    // ADC_INPUTCHAN_EXT1,
    // ADC_INPUTCHAN_EXT0,
                              .totalChannels = ADC_SEQUENCE_LENGTH,
                              .sequenceMode = ADC_CONV_LOOP,
                              .sequenceIntEnable = false,
                              .convIntEnable = false
    const dma_transfer_config_t adcTransferConfig = {
    .srcAddr = (uint32_t)&ADC0->FIFO,
    .destAddr = (uint32_t)&ADC0_Control.ADC_ConversionBuff,//g_adc_result[0U],
    .destOffset = 0x02U,
    .srcOffset = 0x00U,
    .srcTransferSize = DMA_TRANSFER_SIZE_2B,
    .destTransferSize = DMA_TRANSFER_SIZE_2B,
    .srcModulo = DMA_MODULO_OFF,
    .destModulo = DMA_MODULO_OFF,
    .transferLoopByteCount = (ADC_SEQUENCE_LENGTH * 2),
    .loopTransferConfig = &adcLoopTransferConfig,
    .destLastAddrAdjust = -(ADC_SEQUENCE_LENGTH * 2),
    .interruptEnable = false//true//false
    /* Initialize adc instance */
    status |= ADCJqr_Init();
    status_t ADCJqr_Init(void)
    status_t status = STATUS_SUCCESS;
    ADC_DRV_ConfigConverter(ADC_INST, &adcInitConfig);
    /* Initialize DMA module & channels */
    status |= DMA_DRV_Init(&dmaController_State,
        &dmaControllerInitConfig,
        dmaChnStateArray,
        dmaChnConfigArray,
        DMA_CONFIGURED_CHANNELS_COUNT);
    /* Initiate DMA Loop Transfer */
    status |= DMA_DRV_ConfigLoopTransfer(dmaControllerChn0InitConfig.virtChnConfig, &adcTransferConfig);
    status |= DMA_DRV_StartChannel(DMA_CHN0_NUMBER);
    // Enable temperature sensor
    ADC0->CTRL |= 0x1 << ADC_CTRL_TSEN_SHIFT;
    // ADC_DRV_ConfigConverter(ADC_INST, &adcInitConfig);
    ADC_DRV_Start(ADC_INST);
    return status;
    • ethanE 离线
      ethanE 离线
      ethan
      Diga 改过了这个以后,也是一样的问题。
      详细描述一下,漏了一个提示,就是application单独这样运行没问题,从bootloader跳转到application以后,applicaiton里面的adc概率性不工作,bootloader程序没有对adc和dma进行任何操作
      • ethanE 离线
        ethanE 离线
        ethan
        重启后有部分概率发现包括mcu内置温度的adc以及其他所有adc通道数值为0,请问怎么调试和定位问题
          这个是不是有点问题?ADC0_Control.ADC_ConversionBuff 已经是指针了,又对指针进行取址。
          另外如果要调试的话,可以把ADC->FIFO 的高16bit也拿出来,里面显示了当前ADC转换结果的通道号,即DMA 一次搬运4个bytes
          • ethanE 离线
            ethanE 离线
            ethan
              你可以把ADC->FIFO 的高16bit拿出来,check通道号有没有问题。
              ADC只要使能了,触发一下就会工作,你可以check一下ADC的功能时钟是不是受到影响
              yongfuY
              yongfu
