  4. YCT生成的KEIL环境代码,取消MicroLIB,编译报错
4 帖子 2 发布者 3.3k 浏览
  • HarlanH 离线
    HarlanH 离线
    Harlan YunTu
    YCT生成的KEIL环境代码,不使用MicroLIB,编译会报错,请问如何解决?
    8957965a-9b5b-45a6-a8cf-2f5f30498c2f-image.png 0982c300-eb36-4f75-a834-aa521bb467b7-image.png
      建议客户开启Microlib。
      • MicroLib is designed for deeply embedded applications.
      • MicroLib is optimized to use less code and data memory than using the ARM standard library.
      • MicroLib has been designed to work without an operating system, however this does not prevent it being used together with any OS or RTOS such as Keil RTX.
      • MicroLib contains no file I/O or wide character support.
      • As MicroLib has been optimized to minimize code size, some functions will execute more slowly than the standard C library routines available in the ARM compilation tools.
      https://www.keil.com/arm/microlib.asp
        看错误上要在yt-link里增加额外的x$fpl$区域。
        为什么要取消microlib呢。
        • HarlanH 离线
          HarlanH 离线
          Harlan YunTu
          用户要把我们的底层驱动移植到他们项目里,他们项目原本没有应用microlib,然后发现的这个问题
            建议客户开启Microlib。
