  2. Announcements
  3. MCAL Release Notes
  4. YTM32B1ME1_0_8_0 Release Notes
已定时 已固定 已锁定 已移动 MCAL Release Notes
1 帖子 1 发布者 1.8k 浏览
    Overview
    YUNTU MCAL(Microcontroller Abstract Layer) software package is designed by YTMicro AE team to support customers on AUTOSAR compliant application software development. The YUNTU MCAL is developed according to the AUTOSAR CP Release v4.4.0 standard.
    Package Name Version Release Date
    YTM32B1ME1_0_8_0 0_8_0 2026-03-06
    Support Toolchains
    YUNTU MCAL software package release are tested and validated with the following toolchains/IDE:
    Recommended Configuration Tool:
    • YCT(Yuntu Config Tool) v2.7.7 or higher version
    Tips: It can be downloaded from YTMicro Account or updated from the installed older version YCT.
    Recommended IDE/Compilers:
    • ARM Keil v5.36 or higher version IDE
    • IAR v8.40 or higher version IDE
    • VSCode v1.80 or higher version IDE with Ninja, CMake and GCC/IAR/Keil as compiler
    • GCC for ARM v10.3 or higher version
    Recommended debuger:
    • SEGGER J-INK v9.2 or higher hardware + v6.96 or higher software/driver with required YTM32B1ME05 and YTM32B1MD14 patch installed.
    Release List
    • [New]-[Platform]-[EL0: ] Init Platform module for YTM32B1ME1, Support BVT and SecureBoot config.
    • [New]-[CddPpu]-[EL0: ] Init CddPpu module for YTM32B1ME1
    • [New]-[Icu]-[EL0: ] Init Icu module for YTM32BIME1, support eTMR, Port, ACMP and MPWM based Icu channel configuration and code generation.
    • [New]-[CddDma]-[EL0: ] Init CddDma module for YTM32B1ME1
    • [New]-[Spi]-[EL0: ] Init Spi module for YTM32B1ME1
    • [New]-[Pwm]-[EL0: ] Init the Pwm module for YTM32BIME1, support eTMR and MPWM based PWM channel configuration and code generation.
    • [New]-[Mcu]-[EL0: ] Init Mcu module for YTM32B1ME1.
    • [New]-[Ocu]-[EL0: ] Init Ocu module for YTM32BIME1
    • [New]-[Adc]-[EL0: ] Init the Adc module for YTM32B1ME1.
    • [New]-[Port]-[EL0: ] Init Port module for YTM32BIME1.
    • [New]-[Gpt]-[EL0: ] Init Gpt module for YTM32B1ME1.
    • [New]-[Crc]-[EL0: ] Init Crc module for YTM32B1ME1.
    • [New]-[CddI2c]-[EL0: ] Init CDDI2c module for YTM32B1ME1.
    • [New]-[Dio]-[EL0: ] Dio supports reading from and writing to the pins of YTM32B1ME1.
    • [New]-[CddUart]-[EL0: ] Init CddUart module for YTM32B1ME1,update CddUart Idle demo.
    • [New]-[Eep]-[EL0: ] Init the Eep module for YTM32BIME1
    • [New]-[Lin]-[EL0: ] Init Lin module for YTM32B1ME1.
    • [New]-[Crypto]-[EL0: ] Init the Crypto module for YTM32BIME1
    • [New]-[Wdg]-[EL0: ] Init the Wdg module for YTM32BIME1
    Annex
    Release list naming rule
    Each release list item shall contain the following elements:
    [Type] - [Sub-Type/Module] - [Effect_Level] [Brief/Overview Description][Reference/Details Link]
    • [Type]
      • Fix: Bug fixes / issue resolution
      • Opt: Code performance optimization
      • New: New feature implementation
      • Demo: Example / demonstration project
      • Doc: Documentation updates
    • [Sub-Type/Module]
      • MCAL: Mcu/Dio/Port/Can/Lin/Spi/Gpt/Pwm/Adc/Icu/Ocu/Fls/Fee/Platform/CddUart/CddSai/CddPpu/CddI2c/CddDma/CddTrg
      • SafLib: CorTst/RamTst/FlsTst/IntTst/WdgTst/CrcTst/DmaTst/PpuTst/EfmTst/StkTst/EccTst/FmuTst
      • GUI: the YCT XDM config GUI update for the MCAL/SafLib SW package, the YCT Vue config GUI update for the SDK/Middleware SW package(no code change/modification)
    • [Effect_Level]
      • 0: No effect to the old version SW/project
      • 1: Recommend but optional to update, for example the performance optimization
      • 2: Must update for a specified SW module/components if the customer application used the related feature/functionality
      • 3: Must update for a specified SW module/components if it is used
      • 4: Must update if the SDK/MCAL/SafLib package is used
    • [Brief/Overview Description]
      • [Type] = Fix: Fixed the xxx issue/bug of the yyy HW/SW functionality/feature caused by condition
      • [Type] = Opt: Optimized the performance of the yyy HW/SW functionality/feature
      • [Type] = New: Added the new feature/functionality support of xxx
      • [Type] = Demo: added/updated the demo project: brief description
    • [Reference/Details Link]
      • Errata: give out the detailed Errata number
      • others: the link to the bug/issue analysis, it can be:
        • Link to a YUNTU form post [if it is derived from a FAE/customer feedback]
        • Link to a YUNTU form blog [if it is derived from a YUNTU form blog discussion]
    Disclaimer
    Copyright and Contact Information
    YTMicro and its subsidiaries reserve the right to change, correct, enhance, modify and improve YTMicro products or this document at any time without notice. Before placing an order, purchasers should obtain and understand the latest relevant information about the products. YUNTU's products are sold according to YUNTU team and sales conditions at the time of order confirmation. Purchasers have the sole responsibility for selecting, choosing and using YUNTU products, and YUNTU has no responsibility for assisting purchasers in product design and application. YUNTU does not grant any express or implied license to any intellectual property herein. Resale of YUNTU products with information different from that described herein will make any warranty of YUNTU for such product void. YTMicro and YTMicro logo are trademarks of YTMicro. All other product or service names are the property of their respective owners. The information in this document replaces and supersedes any previously provided information in any prior version of this document. © 2020 - 2026 YUNTU Microelectronics co.,ltd. All rights reserved.
    Contact us: Website: www.ytmicro.com.
