  4. cmake命令行编译问题
cmake命令行编译问题
4 帖子 2 发布者 3.8k 浏览
  • Maple12138M 离线
    Maple12138M 离线
    Maple12138 YunTu
    我这边cmake编译报错
    客户端cmake爆这个错误
      mkdir build
      cd build
      PS C:\Users\Frankie\Downloads\test_project\Adc_All_Channel_Demo> cd .\build\
      PS C:\Users\Frankie\Downloads\test_project\Adc_All_Channel_Demo\build> cmake .. -DARM_CPU="cortex-m33" -DDEVICE_NAME="YTM32B1MD1" -DTOOLCHAIN="GCC" -DCMAKE_TOOLCHAIN_FILE="./../cmake/gcc.cmake" -G Ninja
      -- The C compiler identification is GNU 10.3.1
      -- The CXX compiler identification is GNU 10.3.1
      -- Detecting C compiler ABI info
      -- Detecting C compiler ABI info - done
      -- Check for working C compiler: C:/Users/Frankie/AppData/Roaming/yt_config_tool/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-gcc.exe - skipped
      -- Detecting C compile features
      -- Detecting C compile features - done
      -- Detecting CXX compiler ABI info
      -- Detecting CXX compiler ABI info - done
      -- Check for working CXX compiler: C:/Users/Frankie/AppData/Roaming/yt_config_tool/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-g++.exe - skipped
      -- Detecting CXX compile features
      -- Detecting CXX compile features - done
      -- The ASM compiler identification is GNU
      -- Found assembler: C:/Users/Frankie/AppData/Roaming/yt_config_tool/gcc-arm-none-eabi-10.3-2021.10/bin/arm-none-eabi-gcc.exe
      -- Configuring done (1.8s)
      -- Generating done (0.0s)
      CMake Warning:
        Manually-specified variables were not used by the project:
          DEVICE_NAME
          TOOLCHAIN
      -- Build files have been written to: C:/Users/Frankie/Downloads/test_project/Adc_All_Channel_Demo/build
      PS C:\Users\Frankie\Downloads\test_project\Adc_All_Channel_Demo\build> ninja
      [31/31] Linking C executable Adc_All_Channel_Demo.elf
         text    data     bss     dec     hex filename
         9948     329    2160   12437    3095 Adc_All_Channel_Demo.elf
      Maple12138M 1 条回复 最后回复
      • Maple12138M 离线
        Maple12138M 离线
        Maple12138 YunTu
          删除build重新执行
          • Maple12138M Maple12138 将这个主题标记为已解决,在
          • J JMHL 在 中 引用了 这个主题
