  4. YTM32B1ME0 读取ADC FIFO数据的通道号与配置通道不一致
12 帖子 5 发布者 6.3k 浏览
  • FarleyHuangF 离线
    FarleyHuangF 离线
    FarleyHuang
    Diga 请问下问题1出现的原因是什么:
    1.我配置ADC的一组为: 通道 0,1,12,13;当我读取ADC->FIFO时,读出的通道是0, 12, 9, 9;
    DigaD 1 条回复 最后回复
      在 回复了 FarleyHuang 最后由 编辑
      @FarlyHuang 大抵是因为你下面打开了 Memory 窗口,0x4004004C 正好是 ADC->FIFO 寄存器的地址,跟读左侧的寄存器窗口效果是一样的
      • FarleyHuangF 离线
        FarleyHuangF 离线
        FarleyHuang
        写于 最后由 FarleyHuang 编辑
        Diga 我现在把memory读取ADC-> FIFO的视图关闭了,现在读取通道号仍然与配置不一样
        下次是我调试的配置:
        /* adc_config0 */
        const adc_converter_config_t adc_config0={
            .clockDivider=0,
            .startTime=12,
            .sampleTime=2,
            .overrunMode=false,
            .autoOffEnable=false,
            .waitEnable=false,
            .align=ADC_ALIGN_RIGHT,
            .dmaWaterMark=0,
            .dmaEnable=false,
            .sequenceConfig={
                .sequenceMode=ADC_CONV_LOOP,
                .sequenceIntEnable=false,
                .convIntEnable=false,
                .readyIntEnable=false,
                .ovrunIntEnable=false,
                .sampIntEnable=false,
                .channels={
                    ADC_INPUTCHAN_EXT0,
                    ADC_INPUTCHAN_EXT1,
                    ADC_INPUTCHAN_EXT12,
                    ADC_INPUTCHAN_EXT13,
                .totalChannels=4,
            .compareConfig={
                .compareEnable=false,
                .compareAllChannelEnable=false,
                .compHigh=4095,
                .compLow=0,
                .compIntEnable=false,
        #include "adc.h"
        #define ADC_INST 0U
        adc_converter_config_t get_adc_config0;
        uint8_t set_adc_sequence_cnt = 2;
        uint8_t get_adc_sequence_cnt = 2;
        void ADC_Init(void)
            ADC_DRV_ConfigConverter(ADC_INST,&adc_config0);
            ADC_DRV_Start(ADC_INST);
            //get adc sequence length
            set_adc_sequence_cnt = adc_config0.sequenceConfig.totalChannels;
            ADC_DRV_GetConverterConfig(ADC_INST, &get_adc_config0);
            get_adc_sequence_cnt = get_adc_config0.sequenceConfig.totalChannels;
        uint32_t adc_FIFO_values[] = {0,0,0,0};
        uint16_t adc_channels_values[] = {0,0,0,0};
        void ADC_Get_Value_10ms(void)
            uint32 reg_value = 0;
            for (uint8_t i = 0; i < set_adc_sequence_cnt; i++)
                reg_value = ADC_DRV_ReadSeqtagAndData(ADC_INST);
                uint8_t channel_id = reg_value>>16;
                // uint8_t channel_id = (reg_value>>16)&0x1f;
                uint16_t chan_raw_data = (reg_value&0x0000ffff);
                adc_FIFO_values[i] = reg_value;
                adc_channels_values[i] = channel_id;
                if(channel_id == 0)//ADC0_SE0
                    uint16 ADC_mV_IntPackVolt = 0;
                    ADC_mV_IntPackVolt = (reg_value&0x0000ffff)*3300/4096;
                    //test code to view the convert result of ADC
                    ADC_mV_IntPackVolt = 1100;
        DigaD 番茄+两个蛋番 2 条回复 最后回复
          @FarlyHuang 看起来还是有个什么东西在读取 ADC->FIFO ,你读到的第三个值 0x9094C,应该就是 FIFO 空了之后的值。也就是你软件读了两个值之后,ADC->FIFO 已经空了。
          可以再 check 一下你的调试环境,如果可以的话,尽量换别的 IDE 再试试(KEIL,IAR,OZone)
          • FarleyHuangF 离线
            FarleyHuangF 离线
            FarleyHuang
            Diga 好的, 我用OZone尝试一下
            • FarleyHuangF 离线
              FarleyHuangF 离线
              FarleyHuang
              Diga 感谢指导, 使用OZone 尝试后,读取的通道ID与配置项一致了;
              顺便请教一下,如果使用vs code debug情况下,怎么排查问题是哪里引起的乱序呢? 因为使用vs code是比较方便的
              FrankieF 1 条回复 最后回复
                @FarlyHuang 关于vscode debug,你可以在这个地方问题:https://github.com/Marus/cortex-debug
                • FarleyHuangF 离线
                  FarleyHuangF 离线
                  FarleyHuang
                  Frankie 好的,感谢
                  • DigaD Diga 在 中 引用了 这个主题
                  • 番茄+两个蛋番 离线
                    番茄+两个蛋番 离线
                    FarleyHuang 你好,初始化的时候已经开启了ADC_DRV_Start,后续获取后还需要再次调用吗?这是为什么啊?
                    YTCQ_shejiwangY 1 条回复 最后回复
                    • YTCQ_shejiwangY 离线
                      YTCQ_shejiwangY 离线
                      YTCQ_shejiwang YunTu
                      在 回复了 番茄+两个蛋 最后由 编辑
                      软件触发,触发模式不为Countinous,是需要再次触发的(Start)。
