  4. YTM32B1MD14 - MPU Configuration - Can I grant permission rw-|r-- for a memory section?
5 帖子 2 发布者 2.0k 浏览
  • nguyan2N 离线
    nguyan2N 离线
    nguyan2
    Hello all,
    For one memory section, I want to grant read-write access for privileged mode and read-only access for unprivileged mode (rw-|r--).
    However, I don’t see any permission option like this in the source code generated by the YTConfig Tool.496d9aea-f9e4-4d33-a28e-d30ea595d4f1-image.png
    I also checked the ARMv8-M documentation, and it seems that this kind of permission is not directly supported.22a54749-f50a-4e8d-859b-7eeeb5fbf8b8-image.png
    Is there any known solution or workaround for this case?
    Thanks in advance!
      写于 最后由 Diga 编辑
      ARMv8 can't support your case.
      If set AP = 0b00, only privaleged code can read/write memory, user mode can't read or write;
      If set AP = 0b01, any privaleged code can read/write memory, user mode also;
      nguyan2N 1 条回复 最后回复
      • nguyan2N 离线
        nguyan2N 离线
        nguyan2
        Diga 在 YTM32B1MD14 - MPU Configuration - Can I grant permission rw-|r-- for a memory section? 中说:
        Hi, thanks for your reply. Do you have any idea about the workaround for my case?
          写于 最后由 Diga 编辑
          ARMv7 can support your case. YTM32B1HA01's core is CORTEX-M7 with ARMv7.
          nguyan2N 1 条回复 最后回复
          • nguyan2N 离线
            nguyan2N 离线
            nguyan2
            Thanks for your suggestion but unfortunately we can't change the chipset.
            Is there any mechanism or any demo code to switch between Supervisor mode and User mode for YTM32B1MD14?
            QQT-EthanQ
            QQT-Ethan
            LSNL
            LSN
            cc123456C
            cc123456
            lp666L
            lp666
            lfL
            lf
