  4. [YT32B1LE05]采样ADC DMA的方式获取ADC数据,其ADC值出现了4095的情况
已定时 已固定 已锁定 已移动 YTM32B1L系列
8 帖子 2 发布者 245 浏览
  • ryw3509R 离线
    ryw3509R 离线
    ryw3509
    无论是单个通道还是多个通道,在某个时候采集的ADC值出现了4095的情况,怎么处理?谢谢~
    • ryw3509R 离线
      ryw3509R 离线
      ryw3509
      在1ms的定时任务中加入了:
      ADC_DRV_Start(ADC_INST);
      在10ms的定时任务获取ADC的值并打印出来。
      • ryw3509R 离线
        ryw3509R 离线
        ryw3509
        /* adc_config0 */
        const adc_converter_config_t adc_config0={
        .clockDivider=0,
        .startTime=32,
        .sampleTime=5,
        .overrunMode=false,
        .autoOffEnable=false,
        .waitEnable=false,
        .align=ADC_ALIGN_RIGHT,
        .dmaWaterMark=2,
        .dmaEnable=true,
        .sequenceConfig={
        .sequenceMode=ADC_CONV_LOOP,
        .sequenceIntEnable=true,
        .convIntEnable=false,
        .readyIntEnable=false,
        .ovrunIntEnable=false,
        .sampIntEnable=false,
        .channels={
        ADC_INPUTCHAN_EXT2,
        ADC_INPUTCHAN_EXT4,
        ADC_INPUTCHAN_EXT5,
        .totalChannels=3,
        .compareConfig={
        .compareEnable=false,
        .compareAllChannelEnable=false,
            .compHigh=4095,
            .compLow=0,
            .compIntEnable=false,
        • ryw3509R 离线
          ryw3509R 离线
          ryw3509
          ADC_Init接口函数:
          ADC_DRV_ConfigConverter(0,&adc_config0);
          DMA_DRV_Init(&dmaState,&dmaController_InitConfig,dmaChnState,dmaChnConfigArray,NUM_OF_CONFIGURED_DMA_CHANNEL);
          /* Initiate DMA Loop Transfer */
          adcTransferConfig.srcAddr = (uint32_t)&ADC0->FIFO;
          adcTransferConfig.destAddr = (uint32_t)&g_adc_result[0U];
          DMA_DRV_ConfigLoopTransfer(0U, &adcTransferConfig);
          DMA_DRV_StartChannel(0U);
          • ryw3509R 离线
            ryw3509R 离线
            ryw3509
            const dma_channel_config_t dma_config0 = {
            .virtChnConfig=0,
            .source=DMA_REQ_ADC0,
            .callback=NULL,
            .callbackParam=NULL,
            const dma_channel_config_t *const dmaChnConfigArray[NUM_OF_CONFIGURED_DMA_CHANNEL] = {
            &dma_config0,
            const dma_user_config_t dmaController_InitConfig = {
            .haltOnError = false
            dma_chn_state_t dma_config0_State;
            dma_chn_state_t *const dmaChnState[NUM_OF_CONFIGURED_DMA_CHANNEL]={
            &dma_config0_State,
            dma_state_t dmaState;
            dma_loop_transfer_config_t adcTransferConfigLoopConfig = {
            .triggerLoopIterationCount=10,
            .srcOffsetEnable=false,
            .dstOffsetEnable=true,
            .triggerLoopOffset=-16,
            .transferLoopChnLinkEnable=false,
            .transferLoopChnLinkNumber=0,
            .triggerLoopChnLinkEnable=false,
            .triggerLoopChnLinkNumber=0,
            dma_transfer_config_t adcTransferConfig = {
            .srcAddr=(uint32_t)0,
            .destAddr=(uint32_t)0,
            .srcOffset=0,
            .destOffset=0x02U,
            .srcTransferSize=DMA_TRANSFER_SIZE_2B,
            .destTransferSize=DMA_TRANSFER_SIZE_2B,
            .srcModulo=DMA_MODULO_OFF,
            .destModulo=DMA_MODULO_OFF,
            .transferLoopByteCount=16,
            .srcLastAddrAdjust=0,
            .destLastAddrAdjust=-16,
            .interruptEnable=false,
            .loopTransferConfig=&adcTransferConfigLoopConfig,
            • DigaD 在线
              DigaD 在线
              配置截图跟生成代码不太一致,DMA 的 watermark 应该设置为 1
              ryw3509R 1 条回复 最后回复
              • ryw3509R 离线
                ryw3509R 离线
                ryw3509
                Diga 你好,你说的配置和截图不一致,我这里截图和配置是复制的时候手误造成的,按照截图所述配置ADC0_SE2和ADC0_SE4,其.dmaWaterMark=1,这个应该是没有问题的。
                无论是单通道还是多通道采样,都出现了adc值为4095的现象。
                还请协助给看下问题的排查方向,谢谢~
                • DigaD 在线
                  DigaD 在线
                  可以开一下 AWDG 的中断,当转换出来的结果为 0xFFF时,进入中断,看一下当前 ADC 的状态。不过怀疑可能是读空值,即当 ADC FIFO 为空时,仍去读取 ADC FIFO 值。
                  另外可以参考下这个
                  https://forum.ytmicro.com/topic/444/adc采样漂移或不准问题排查方法
                • demo
                  19
                  can
                  16
                  QQT-EthanQ
                  QQT-Ethan
                  ganyongchaoG
                  ganyongchao
                  DigaD
                  yishui66Y
                  yishui66
                  carpeC
                  carpe
                  YanglzY
                  Yanglz
                  jiankang_wangJ
                  wangfuqiW
                  wangfuqi
                  chenxingC
                  chenxing
                  DZHD
                  DZH
                  xulinhuiX
                  xulinhui
                  HAIYANGH
                  HAIYANG
                  Jacky_tanJ
                  Jacky_tan
