  4. Demo_PWM_同一个周期内立即更新占空比
已定时 已固定 已锁定 已移动 YT SDK
demoetmrpwm
11 帖子 3 发布者 744 浏览
  • qinzhaoQ 离线
    qinzhaoQ 离线
    qinzhao YunTu
    1. 背景
      特殊应用场合出现同一个周期内,更新两次占空比,SDK自带DEMO会更新不进去
    2. 需求
    3. 芯片系列:MC0,MD,ME,LE
    4. 功能需求描述
    5. 特殊应用场合出现同一个周期内,更新两次占空比,无法更新
    6. 代码包:MCAL x.x.x/SDK x.x.x/RegCode
    7. 编译器:IAR/Keil/Gcc
    8. 解决方案描述
      1.模拟同一个周期内多次更新占空比,去掉原demo里的两次更新占空比之间的延时
      c8f56cfb-50db-449d-bfc7-c602e62a00d2-image.png [图片]
      此时PWM输出为第一次占空比设置的0%占空比。
      2.将原来regisiter loading Opportunity配置的synchronized with counter matching MOD改为synchronized with register loading trigger source。
    9. 示例说明
      2.将PWM设置为软触发更新
      [图片]
      3.在代码中将eTMR_DRV_SetLdok()函数改为eTMR_DRV_SyncWithSoftTrigger(ETMR_INST)
    int main(void)
        /* USER CODE BEGIN 1 */
        /* USER CODE END 1 */
        Board_Init();
        /* USER CODE BEGIN 2 */
        /* PWM is generated when eTMR enable, the duty cycle is configured in the initial function */
        eTMR_DRV_Enable(ETMR_INST);
        OSIF_TimeDelay(10);
        /* The following code shows how to switch the different duty cycle */
        /* channel 2 duty cycle is 50% */
        eTMR_DRV_UpdatePwmChannel(ETMR_INST, ETMR_CHANNEL_INDEX0, 0x4000U, 0);
        /* channel 3 duty cycle is 75% */
        eTMR_DRV_UpdatePwmChannel(ETMR_INST, ETMR_CHANNEL_INDEX1, 0x6000U, 0);
        eTMR_DRV_SetLdok(ETMR_INST);
        OSIF_TimeDelay(10);
        /* channel 2 duty cycle is 100%, here is the workaround for 100% duty cycle
         * when channel is right align, value0 is configured as 0
        g_etmrBase[ETMR_INST]->CH[ETMR_CHANNEL_INDEX0].VAL0 = 0;
        g_etmrBase[ETMR_INST]->CH[ETMR_CHANNEL_INDEX0].VAL1 = g_etmrBase[ETMR_INST]->MOD + 1;
        /* channel 3 duty cycle is 100%
         * when channel is left/center/asymmetrical align, value0 is configured as 1
        g_etmrBase[ETMR_INST]->CH[ETMR_CHANNEL_INDEX1].VAL0 = 1;
        g_etmrBase[ETMR_INST]->CH[ETMR_CHANNEL_INDEX1].VAL1 = g_etmrBase[ETMR_INST]->MOD + 1;
        OSIF_TimeDelay(10);
        /* channel 2 duty cycle is 0 */
        eTMR_DRV_UpdatePwmChannel(ETMR_INST, ETMR_CHANNEL_INDEX0, 0, 0);
        /* channel 3 duty cycle is 0 */
        eTMR_DRV_UpdatePwmChannel(ETMR_INST, ETMR_CHANNEL_INDEX1, 0, 0);
        ***eTMR_DRV_SyncWithSoftTrigger(ETMR_INST);***
        //OSIF_TimeDelay(10);
        /* channel 2 duty cycle is 0x6000 */
        eTMR_DRV_UpdatePwmChannel(ETMR_INST, ETMR_CHANNEL_INDEX0, 0x6000U, 0);
        /* channel 3 duty cycle is 0x4000 */
        eTMR_DRV_UpdatePwmChannel(ETMR_INST, ETMR_CHANNEL_INDEX1, 0x4000U, 0);
        /* USER CODE END 2 */
        /* Infinite loop */
        /* USER CODE BEGIN WHILE */
        while (1)
            /* USER CODE END WHILE */
            /* USER CODE BEGIN 3 */
        /* USER CODE END 3 */
    可以输出最新的更新的占空比值,不再需要等到COUNTER值等于MOD值更新。
    输出波形:
    ee999e18-4555-403b-8f5e-639d3219371c-image.png [图片]
    5. 工程代码
    8b54813e-6ed9-4df8-9464-81756d2f7667-Etmr_Pwm_Demo.zip
    • z1009591161Z 离线
      z1009591161Z 离线
      z1009591161
      通过Ozone看占空比寄存器,此方法确实可以实现在一个周期内更改两次占空比,实际输出占空比为最后一次更改的占空比。
      • qinzhaoQ 离线
        qinzhaoQ 离线
        qinzhao YunTu
        TungDoT 1 条回复 最后回复
        • TungDoT 离线
          TungDoT 离线
          TungDo
          在 回复了 qinzhao 最后由 编辑
          qinzhao Hi there, could you please give me the link of this configure tool?
          • qinzhaoQ 离线
            qinzhaoQ 离线
            qinzhao YunTu
            帖子附件里有,下面是链接:
            https://yt-static-media.oss-cn-hangzhou.aliyuncs.com/nodebb/24/e818fe45-5516-4885-a8ad-225aeb4c86ae.zip
            • qinzhaoQ 离线
              qinzhaoQ 离线
              qinzhao YunTu
              The link in pdf.云途开发生态介绍.pdf
              TungDoT 2 条回复 最后回复
              • TungDoT 离线
                TungDoT 离线
                TungDo
                qinzhao do you have another version in english?
                • TungDoT 离线
                  TungDoT 离线
                  TungDo
                  qinzhao many thanks for your support!
                  • qinzhaoQ 离线
                    qinzhaoQ 离线
                    qinzhao YunTu
                    download link:https://account.ytmicro.com/#/login,
                    After registering and logging in, you can download it.
                    TungDoT 1 条回复 最后回复
                    • TungDoT 离线
                      TungDoT 离线
                      TungDo
                      qinzhao Do I need to pay any fees to use the YTC tool?
                      • qinzhaoQ 离线
                        qinzhaoQ 离线
                        qinzhao YunTu
                        ytc tools are free
                      • demo
                        19
                        can
                        18
