<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[YTM32B1MD2_SafLib_3_0_0 Release Notes]]></title><description><![CDATA[<h1>1. Overview</h1>
<hr />
<p dir="auto">YUNTU SafLib (Safety Library) provides peripheral self-tests and software safety mechanisms for AUTOSAR application integration. This document describes SafLib <strong>3.0.0</strong> for <strong>YTM32B1MD2</strong>.</p>
<blockquote>
<p dir="auto"><strong>Required dependency: MCAL 3.0.0.</strong> SafLib 3.0.0 must be integrated with <strong>MCAL 3.0.0</strong>.</p>
</blockquote>
<h2>1.1 Release Type</h2>
<p dir="auto">Initial Release — SafLib 3.0.0. This is the first SafLib release for YTM32B1MD2; there is no previous release.</p>
<p dir="auto"><strong>Status: Internal Release Notes</strong> | Release Date: TBC | Issue Snapshot: 2026-10-28</p>
<li><strong>MD2 Module Support</strong> — Added ClkTst, CrcTst, DmaTst, EccTst, EfmTst, FlsTst, RamTst, StkTst and WdgTst adaptations with related tests.</li>
<li><strong>DmaTst Configuration</strong> — Improved startup-test defaults, runtime-test configuration and DMA channel validation.</li>
<li><strong>Stack Overflow Details</strong> — Added StkTst_GetDetailsResult() and its YCT switch to distinguish MSP and PSP overflow.</li>
<li><strong>EccTst Interrupt Handling</strong> — Fixed application hangs when ECC flags are already pending before the test; the ISR is installed before interrupts are enabled.</li>
<th>Item</th>
<th>Previous Release / Baseline</th>
<td>SafLib Version</td>
<td>N/A (first release)</td>
<td>3.0.0</td>
<td>Target Device</td>
<td>N/A</td>
<td>YTM32B1MD2</td>
<td>AUTOSAR CP</td>
<td>N/A</td>
<td>v4.4.0</td>
<td>MCAL Dependency</td>
<td><strong>MCAL 3.0.0 (required)</strong></td>
<hr />
<p dir="auto">YUNTU SafLib software package uses the following toolchains / IDEs:</p>
<th>IDE / Compiler</th>
<th>Minimum Version</th>
<th>Notes</th>
<td>IAR</td>
<td>v9.50</td>
<td></td>
<td>VSCode v1.80</td>
<td>GCC for ARM</td>
<td>v10.3</td>
<td></td>
<td>Green Hills</td>
<td>v2022.1.4</td>
<td></td>
<li><strong>Required</strong>: target-device support patch installed</li>
<h1>3. Release List</h1>
<hr />
<p dir="auto">The following list summarizes changes for YTM32B1MD2:</p>
<li>[New]-[EfmTst]-[0] <a href="https://project.feishu.cn/ytsw2/issues/detail/7059313825" rel="nofollow ugc">Add MD2 EfmTst support with updated configuration, test projects and fault injection coverage</a></li>
<li>[New]-[DmaTst]-[TBC] <a href="https://project.feishu.cn/ytsw2/issues/detail/7059498864" rel="nofollow ugc">Add MD2 DmaTst support and related tests</a></li>
<li>[Opt]-[DmaTst]-[1] <a href="https://project.feishu.cn/ytsw2/issues/detail/7059690470" rel="nofollow ugc">Improve DmaTst YCT defaults, runtime configuration and DMA channel validation</a></li>
<li>[New]-[ClkTst]-[2] <a href="https://project.feishu.cn/ytsw2/issues/detail/7059650592" rel="nofollow ugc">Add MD2 ClkTst support and related tests</a></li>
<li>[New]-[WdgTst]-[2] <a href="https://project.feishu.cn/ytsw2/issues/detail/7060437814" rel="nofollow ugc">Add MD2 WdgTst support and related tests</a></li>
<li>[New]-[StkTst]-[0] <a href="https://project.feishu.cn/ytsw2/issues/detail/7066977422" rel="nofollow ugc">Add MD2 StkTst resources, code generation, source code and test support</a></li>
<li>[New]-[RamTst]-[0] <a href="https://project.feishu.cn/ytsw2/issues/detail/7067154916" rel="nofollow ugc">Add MD2 RamTst support and related tests</a></li>
<li>[New]-[FlsTst]-[0] <a href="https://project.feishu.cn/ytsw2/issues/detail/7067345125" rel="nofollow ugc">Add MD2 FlsTst support and related tests</a></li>
<li>[New]-[EccTst]-[2] <a href="https://project.feishu.cn/ytsw2/issues/detail/7067942228" rel="nofollow ugc">Add MD2 EccTst support with SUT, SIT and SQT tests</a></li>
<li>[New]-[CrcTst]-[0] <a href="https://project.feishu.cn/ytsw2/issues/detail/7068123140" rel="nofollow ugc">Add MD2 CrcTst support and related tests</a></li>
<li>[New]-[StkTst]-[0] <a href="https://project.feishu.cn/ytsw2/issues/detail/7082491804" rel="nofollow ugc">Add StkTst_GetDetailsResult() and its YCT switch to distinguish MSP and PSP overflow</a></li>
<li>[Fix]-[EccTst]-[3] <a href="https://project.feishu.cn/ytsw2/issues/detail/7144324550" rel="nofollow ugc">Fix EccTst application hangs caused by pending ECC flags by installing the ISR before enabling interrupts and clearing interrupts after the test</a></li>
<p dir="auto"><em>DmaTst-ISSUE-170 does not specify an effect level; it is marked TBC.</em></p>
<p dir="auto"><em>Type labels for StkTst-ISSUE-177, EccTst-ISSUE-189 are classified from the issue content because the source Type field is empty.</em></p>
<h1>4. Known Issues / Limitation</h1>
<hr />
<h2>4.1 Integration Notes</h2>
<li><strong>EccTst (EL3)</strong>: Update EccTst wherever the module is used. Install the ISR before enabling ECC interrupts, then execute the test and clear interrupts. Revalidate startup and boot-to-application paths with ECC flags already pending.</li>
<li><strong>DmaTst</strong>: Regenerate and review configuration for startup-test defaults, the minimum hardware-channel count, the single runtime container and channel-link constraints.</li>
<li><strong>MD2 Coverage</strong>: The nine module adaptations in Section 3 do not establish support for unlisted modules. Confirm the complete module and device-variant support matrix.</li>
<li><strong>Release Baseline</strong>: Confirm the 3.0.0 version record, package identifier, delivery contents and regression reports. Issue closure does not replace release-package qualification evidence.</li>
<h1>Annex</h1>
<h2>Release list naming rule</h2>
<p dir="auto">Each release list item contains the following elements:</p>
<p dir="auto"><code>[Type]-[Module]-[Effect_Level] [Brief Description / Details Link]</code></p>
<li><strong>Type</strong>: Fix — bug fixes; Opt — optimization; New — new functionality; Demo — demonstration projects; Doc — documentation updates.</li>
<li><strong>Module</strong>: The SafLib module affected by the change. Module names in this document do not constitute a complete device support matrix.</li>
<li><strong>Effect_Level</strong>:
<li><strong>0</strong>: No effect on the previous software version / project.</li>
<li><strong>1</strong>: Update recommended but optional.</li>
<li><strong>2</strong>: Update the affected module if the application uses the related functionality.</li>
<li><strong>3</strong>: Update the affected module if it is used.</li>
<li><strong>4</strong>: Update if the software package is used.</li>
<li><strong>TBC</strong>: The source issue does not specify an effect level.</li>
<li><strong>Details Link</strong>: The linked YT_SafLib issue provides the analysis, corrective action and verification records.</li>
<h1>Disclaimer</h1>
<p dir="auto">YTMicro and its subsidiaries reserve the right to change, correct, enhance, modify and improve YTMicro products or this document at any time without notice. Before placing an order, purchasers should obtain and understand the latest relevant information about the products. YUNTU's products are sold according to YUNTU team and sales conditions at the time of order confirmation. Purchasers have the sole responsibility for selecting, choosing and using YUNTU products, and YUNTU has no responsibility for assisting purchasers in product design and application. YUNTU does not grant any express or implied license to any intellectual property herein. Resale of YUNTU products with information different from that described herein will make any warranty of YUNTU for such product void. YTMicro and YTMicro logo are trademarks of YTMicro. All other product or service names are the property of their respective owners. The information in this document replaces and supersedes any previously provided information in any prior version of this document.</p>
<p dir="auto"><img src="https://forum.ytmicro.com/assets/plugins/nodebb-plugin-emoji/emoji/android/00a9.png?v=1b4819a83c9" class="not-responsive emoji emoji-android emoji--copyright" style="height:23px;width:auto;vertical-align:middle" title=":copyright:" alt="©" /> 2020 - 2026 YUNTU Microelectronics co.,ltd. All rights reserved.</p>
]]></description><link>https://forum.ytmicro.com/topic/2315/ytm32b1md2_saflib_3_0_0-release-notes</link><generator>RSS for Node</generator><lastBuildDate>Wed, 28 Oct 2026 23:17:49 GMT</lastBuildDate><atom:link href="https://forum.ytmicro.com/topic/2315.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Oct 2026 04:18:32 GMT</pubDate><ttl>60</ttl></channel></rss>
